Datasheet ADXL1003 (Analog Devices) - 8
Description | Low Noise, Wide Bandwidth, MEMS Accelerometer |
Pages / Page | 14 / 8 — ADXL1003. Data Sheet. 600. REFERENCE. 500. XOUT DELTA. OVERRANGE. ) (g. … |
File Format / Size | PDF / 518 Kb |
ADXL1003. Data Sheet. 600. REFERENCE. 500. XOUT DELTA. OVERRANGE. ) (g. 400. XOUT. 300. RAT. LTAG. 200. ACCE. STANDBY. UT P. 100. –100
ADXL1003 Data Sheet 6 600 12 REFERENCE 5 500 XOUT DELTA 10 OVERRANGE 4 ) (g 400 8 N ) 3 IO ) (V XOUT V E 300 6 ( RAT T E 2 U L P LTAG T 200 4 VO OU 1 ACCE STANDBY UT P 100 2 0 IN 0 0 –1 –2 –100 –2 0 5 10 15 20 25 30 35 40
016
13.0 13.5 14.0 14.5 15.0 15.5 16.0 16.5 17.0 17.5 18.0
18 0 96- 6-
TIME (µs)
165
TIME (ms)
659 1 Figure 16. XOUT Output Recovery from Standby Mode to Measure Mode Figure 18. Response to Overload Condition, XOUT Delta is Difference from Midscale Voltage
204 z) 200.5 H (k 203 200.0 0V (kHz) 202 Y 199.5 = 5. C N DD 201 E U 199.0 , V Q E CY 200 R N 198.5 F UE K 199 Q C 198.0 O RE F 198 CL 197.5 CK AL O 197 L RN 197.0 E C T 196 IN 196.5 RNAL 195 E T 196.0 IN 194
7
–50 0 50 100 150
01
195.5
6-
3.0 3.2 3.4 3.6 3.8 4.0 4.2 4.4 4.6 4.8 5.0 5.2
19
TEMPERATURE (°C)
59 0 16
SUPPLY VOLTAGE (V)
16596- Figure 17. Internal Clock Frequency vs. Temperature at 5.0 V Supply Voltage (VDD) Figure 19. Internal Clock Frequency vs. Supply Voltage at 25°C Rev. 0 | Page 8 of 14 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE RECOMMENDED SOLDERING PROFILE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION MECHANICAL DEVICE OPERATION OPERATING MODES Measure Mode Standby Mode BANDWIDTH APPLICATIONS INFORMATION APPLICATION CIRCUIT ON DEMAND SELF TEST RATIOMETRIC OUTPUT VOLTAGE INTERFACING ANALOG OUTPUT BELOW 10 kHz INTERFACING ANALOG OUTPUT BEYOND 10 kHz OVERRANGE MECHANICAL CONSIDERATIONS FOR MOUNTING LAYOUT AND DESIGN RECOMMENDATIONS OUTLINE DIMENSIONS ORDERING GUIDE
