Datasheet ADXL1005 (Analog Devices) - 3
DescriptionLow Noise, Wide Bandwidth, MEMS Accelerometer
Pages / Page14 / 3 — Data Sheet. ADXL1005. SPECIFICATIONS. Table 1. Parameter Test. …
File Format / SizePDF / 499 Kb
Data Sheet. ADXL1005. SPECIFICATIONS. Table 1. Parameter Test. Conditions/Comments. Min. Typ. Max. Unit
Data Sheet ADXL1005 SPECIFICATIONS Table 1 Parameter Test Conditions/Comments Min Typ Max Unit
TA = 25°C, VDD = 5.0 V, acceleration = 0 g, unless otherwise noted. All minimum and maximum specifications are guaranteed. Typical specifications may not be guaranteed.
Table 1. Parameter Test Conditions/Comments Min Typ Max Unit
SENSOR Measurement Range ±100 g Linearity1 Percentage of full-scale ±0.25 % Cross Axis Sensitivity2 Z-axis acceleration effect on x-axis ±0.7 % Y-axis acceleration effect on x-axis ±1.5 % SENSITIVITY (RATIOMETRIC TO VDD) Sensitivity DC 20 mV/g Sensitivity Change Due to Temperature3 TA = −40°C to +125°C ±5 % ZERO g OFFSET (RATIOMETRIC TO VDD) 0 g Output Voltage VDD/2 V 0 g Output Range over Temperature4 −40°C to +125°C 9 g NOISE Noise Density 100 Hz to 20 kHz 75 μg/√Hz 100 Hz to 20 kHz, at 3.0 V supply 125 μg/√Hz 1/f Frequency Corner 0.1 Hz FREQUENCY RESPONSE Sensor Resonant Frequency 37.7 42 kHz 5% Bandwidth5 9 kHz 3 dB Bandwidth6 23 kHz SELF TEST Output Change (Ratiometric to VDD) ST low to ST high 420 490 mV Input Voltage Level High, VIH VDD × 0.7 V Low, VIL VDD × 0.3 V Input Current 25 μA OUTPUT AMPLIFIER Short-Circuit Current 3 mA Output Impedance <0.1 Ω Maximum Resistive Load 20 MΩ Maximum Capacitive Load7 No external resistor 100 pF With external resistor 22 nF POWER SUPPLY (VDD) Operating Voltage Range 3.0 5.0 5.25 V Quiescent Supply Current 1.0 1.15 mA Standby Current 225 285 μA Standby Recovery Time (Standby to Measure Mode) Output settled to 1% of final value <50 μs Turn On Time8 <550 μs OPERATING TEMPERATURE RANGE −40 +125 °C 1 Linearity is tested using sine vibration at 100 Hz. 2 Cross axis sensitivity is defined as the coupling of excitation along a perpendicular axis onto the measured axis output. Guaranteed by characterization. 3 Includes package hysteresis from 25°C. 4 Difference between the maximum and the minimum values in temperature range. 5 Specified as a frequency range that is within a deviation range relative to dc sensitivity. The range is limited by an increase in response due to response gain at the sensor resonant frequency. 6 Specified as a frequency range that is within a deviation range relative to dc sensitivity. The range is limited by an increase in response due to response gain at the sensor resonant frequency. 7 For capacitive loads larger than 100 pF, an external series resistor must be connected (minimum 8 kΩ). The output capacitance must not exceed 22 nF. 8 Measured time difference from the instant VDD reaches half its value to the instant at which the output settles to 1% of its final value. Rev. 0 | Page 3 of 14 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE RECOMMENDED SOLDERING PROFILE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION MECHANICAL DEVICE OPERATION OPERATING MODES Measure Mode Standby Mode BANDWIDTH APPLICATIONS INFORMATION APPLICATION CIRCUIT ON DEMAND SELF TEST RATIOMETRIC OUTPUT VOLTAGE INTERFACING ANALOG OUTPUT BELOW 10 kHz INTERFACING ANALOG OUTPUT BEYOND 10 kHz OVERRANGE MECHANICAL CONSIDERATIONS FOR MOUNTING LAYOUT AND DESIGN RECOMMENDATIONS OUTLINE DIMENSIONS ORDERING GUIDE
