Datasheet ADXL356-EP (Analog Devices)
Description | Low Noise, Low Drift, Low Power, 3-Axis MEMS Accelerometer |
Pages / Page | 9 / 1 — Low Noise, Low Drift, Low Power,. 3-Axis MEMS Accelerometer. Enhanced … |
File Format / Size | PDF / 345 Kb |
Low Noise, Low Drift, Low Power,. 3-Axis MEMS Accelerometer. Enhanced Product. ADXL356-EP. FEATURES. FUNCTIONAL BLOCK DIAGRAM
Low Noise, Low Drift, Low Power, 3-Axis MEMS Accelerometer Enhanced Product ADXL356-EP FEATURES FUNCTIONAL BLOCK DIAGRAM Hermetic package offers excellent long-term stability V1P8ANA V1P8DIG RANGE 0 g offset vs. temperature (all axes): 0.75 mg /°C maximum LDO Ultralow noise density (all axes): 80 µg /√Hz V POWER SUPPLY LDO MANAGEMENT Low power, VSUPPLY (LDO enabled) XOUT Y X Measurement mode: 150 µA typical Y ANALOG Z OUT ST1 FILTER Standby mode: 21 µA typical 3-AXIS ZOUT SENSOR ST2 CONTROL User adjustable analog output bandwidth LOGIC STBY TEMP Integrated temperature sensor TEMP ADXL356-EP SENSOR VDDIO Voltage range options
001
V V SUPPLY with internal regulators: 2.25 V to 3.6 V SSIO VSS
16381-
V1P8ANA, V1P8DIG with internal LDO regulator bypassed: 1.8 V
Figure 1.
typical ± 10% 14-terminal, 6.0 mm × 5.6 mm × 2.05 mm, LCC package, 0.26 g ENHANCED PRODUCT FEATURES Supports defense and aerospace applications (AQEC standard) Military temperature range: −55°C to +125°C Controlled manufacturing baseline One assembly/test site One fabrication site Product change notification Qualification data available on request APPLICATIONS Inertial measurement units (IMUs)/altitude and heading reference systems (AHRSs) Platform stabilization systems Structural health monitoring Seismic imaging Tilt sensing Robotics Condition monitoring GENERAL DESCRIPTION
The ADXL356-EP is an analog output, low noise density, low The low noise of the ADXL356-EP over higher frequencies is 0 g offset drift, low power, 3-axis accelerometer with selectable ideal for wireless condition monitoring. measurement ranges. The ADXL356-EP supports the ±10 g and Additional application and technical information can be found ±40 g ranges. in the ADXL356/ADXL357 data sheet. The ADXL356-EP offers industry leading noise, minimal offset drift over temperature, and long-term stability, enabling precision application with minimal calibration. 1 Protected by U.S. Patents 8,472,270; 9,041,462; 8,665,627; 8,917,099; 6,892,576; 9,297,825; and 7,956,621.
Rev. 0 Document Feedback Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rights of third parties that may result from its use. Specifications subject to change without notice. No One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Tel: 781.329.4700 ©2018 Analog Devices, Inc. All rights reserved. Trademarks and registered trademarks are the property of their respective owners. Technical Support www.analog.com
Document Outline FEATURES ENHANCED PRODUCT FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS OUTLINE DIMENSIONS ORDERING GUIDE
