Datasheet IR3826 (Infineon) - 6
ManufacturerInfineon
DescriptionOptiMOS™ IPOL 23 A single-voltage synchronous buck regulator
Pages / Page53 / 6 — IR 8. OptiMOS™ IPOL. 23 A single-voltage synchronous Buck regulator. …
Revision02_04
File Format / SizePDF / 2.3 Mb
IR 8. OptiMOS™ IPOL. 23 A single-voltage synchronous Buck regulator. Typical application diagram. IR3826. Figure 3
IR 8 OptiMOS™ IPOL 23 A single-voltage synchronous Buck regulator Typical application diagram IR3826 Figure 3
IR 8 OptiMOS™ IPOL 23 A single-voltage synchronous Buck regulator Typical application diagram 3 Typical application diagram
5V <Vin<17V NC NC Vin PVin Boot Vo Vcc/ LDO_out SW PGood Vsns PGood
IR3826
ILIM ILIM Fb Rt Comp EnableGnd PGnd
Figure 3 IR3826 basic application circuit
Final Datasheet 6 of 53 V2.4 June 28 2019 Document Outline Revision History Trademarks Disclaimer
