Datasheet HCPL-2201, HCPL-2202, HCPL-2211, HCPL-2212, HCPL-2231, HCPL-2232, HCPL-0201, HCPL-0211, HCNW2201, HCNW2211 (Avago Technologies) - 5
Manufacturer | Avago Technologies |
Description | Very High CMR, Wide VCC Logic Gate Optocouplers |
Pages / Page | 22 / 5 — HCPL-2201, HCPL-2202, HCPL-2211, HCPL-2212, HCPL-2231, HCPL-2232, … |
File Format / Size | PDF / 943 Kb |
Data Sheet Very High CMR, Wide VCC Logic Gate Optocouplers
Package Outline Drawings 8-Pin DIP Package (HCPL-2201/02/11/12/31/32) 9.65 ± 0.25 7.62 ± 0.25 (0.380 ± 0.010) (0.300 ± 0.010) 8 7 6 5 6.35 ± 0.25 TYPE NUMBER (0.250 ± 0.010) AVAGO A XXXXZ OPTION CODE* DATE CODE YYWW UR UL RECOGNITION LOT ID EEE P SPECIAL PROGRAM CODE 1 2 3 4 1.78 (0.070) MAX. 1.19 (0.047) MAX. 5° TYP. 0.254 + 0.076 - 0.051 3.56 ± 0.13 4.70 (0.185) MAX. (0.010 + 0.003) - 0.002) (0.140 ± 0.005) 0.51 (0.020) MIN. 2.92 (0.115) MIN. 1.080 ± 0.320 0.65 (0.025) MAX. DIMENSIONS IN MILLIMETERS AND (INCHES). (0.043 ± 0.013) 2.54 ± 0.25 * MARKING CODE LETTER FOR OPTION NUMBERS (0.100 ± 0.010) "V" = OPTION 060 OPTION NUMBERS 300 AND 500 NOT MARKED. NOTE: FLOATING LEAD PROTRUSION IS 0.25 mm (10 mils) MAX. 8-Pin DIP Package with Gull Wing Surface Mount Option 300 (HCPL-2201/02/11/12/31/32) LAND PATTERN RECOMMENDATION 1.016 (0.040) 9.65 ± 0.25 (0.380 ± 0.010) 8 7 6 5 10.9 (0.430) 6.350 ± 0.25 (0.250 ± 0.010) 1 2 3 4 1.27 (0.050) 2.0 (0.080) 1.780 9.65 ± 0.25 (0.070) (0.380 ± 0.010) 1.19 MAX. 7.62 ± 0.25 (0.047) (0.300 ± 0.010) MAX. 0.254 + 0.076 - 0.051 3.56 ± 0.13 (0.140 ± 0.005) (0.010 + 0.003) - 0.002) 1.080 ± 0.320 0.635 ± 0.25 (0.043 ± 0.013) (0.025 ± 0.010) 2.54 12° NOM. 0.635 ± 0.130 (0.100) (0.025 ± 0.005) BSC DIMENSIONS IN MILLIMETERS (INCHES). LEAD COPLANARITY = 0.10 mm (0.004 INCHES). NOTE: FLOATING LEAD PROTRUSION IS 0.25 mm (10 mils) MAX.
Broadcom AV02-0674EN 5 Document Outline Description Features Applications Functional Diagram Selection Guide Schematic Ordering Information Package Outline Drawings 8-Pin DIP Package (HCPL-2201/02/11/12/31/32) 8-Pin DIP Package with Gull Wing Surface Mount Option 300 (HCPL-2201/02/11/12/31/32) Small-Outline SO-8 Package (HCPL-0201/11) 8-Pin Widebody DIP Package (HCNW2201/11) 8-Pin Widebody DIP Package with Gull Wing Surface Mount Option 300 (HCNW2201/11) Solder Reflow Profile Regulatory Information Insulation and Safety Related Specifications IEC/EN/DIN EN 60747-5-5 Insulation Characteristics (Option 060) IEC/EN/DIN EN 60747-5-5 Insulation Characteristics (HCNW22xx Option 060 ONLY) Absolute Maximum Ratings Recommended Operating Conditions Electrical Specifications Switching Specifications (AC) Package Characteristics
