Datasheet TB67S111PG (Toshiba)
ManufacturerToshiba
DescriptionBiCD Integrated Circuit Silicon Monolithic
Pages / Page15 / 1 — TB67S111PG. Full parallel controlled solenoid driver / unipolar motor …
File Format / SizePDF / 315 Kb
TB67S111PG. Full parallel controlled solenoid driver / unipolar motor driver. Features
Datasheet TB67S111PG Toshiba
TB67S111PG TOSHIBA BiCD Integrated Circuit Silicon Monolithic
TB67S111PG Full parallel controlled solenoid driver / unipolar motor driver
The TB67S111PG is a solenoid driver /unipolar motor driver for full parallel input. Using the BiCD process, the power supply voltage of 45 V, the output voltage of 80 V, and the output current of 1.5 A/ch (absolute maximum rating) are realized.
Features
Weight: 1.11 g (typ.) • BiCD integrated circuit silicon monolithic. • Capable of driving up to four solenoids simultaneously. (4-ch sink driver) • Capable of driving a unipolar stepping motor with a single chip. • Built-in over current detection (automatic return / time control) at each output. • Built-in thermal shutdown detection (automatic return / time control), which detects errors of the whole device. • Output (ERR) pin for thermal shutdown signal. • Built-in output MOSFET for low ON resistance (0.25 Ω (typ.)). • High voltage and large current (as for specifications, please refer to the absolute maximum ratings and operation ranges). • Built-in abnormal detection functions (thermal shutdown detection (TSD), over current detection (ISD), and undervoltage detection (POR)). • Built-in VCC regulator for internal circuit control, capable of being used as the pull-up point of an error output function. Note: Please be careful about the thermal conditions during use. © 2017 1 2017-08-04 Toshiba Electronic Devices & Storage Corporation
