Datasheet IS2083 (Microchip) - 10
Manufacturer | Microchip |
Description | Bluetooth Stereo Audio SoC |
Pages / Page | 65 / 10 — IS2083. Device Overview. Table 2-1. IS2083BM Features. Features. … |
File Format / Size | PDF / 2.9 Mb |
IS2083. Device Overview. Table 2-1. IS2083BM Features. Features. IS2083BM. IS2083BM-2L2. 2.1. IS2083BM Device Ball Diagram. Datasheet
IS2083 Device Overview Table 2-1. IS2083BM Features Features IS2083BM IS2083BM-2L2
Application • Headset/Speaker Headset / Speaker • Bluetooth Audio Transmitter Memory Flash Flash Stereo/Concert mode Yes Yes Package BGA BGA Pin/Ball count 82 82 Dimensions 5.5 mm x 5.5 mm 5.5 mm x 5.5 mm Audio DAC output 2 channel — DAC (single-ended) SNR 95 dB — DAC (cap-less) SNR 95 dB — ADC SNR at 1.8V –88 dB –88 dB I2S audio input Yes Yes I2S digital output Yes Yes MCLK output Yes Yes Analog output Yes — Analog Line-In Yes Yes Analog microphone 2 channel 2 channel Digital microphone 2 channel 2 channel External audio amplifier interface Yes Yes UART with hardware flow control 1 1 USB (Full-speed USB 1.1 interface and Yes Yes battery charging) I2C 1 1 PWM 1 channel 1 channel LED driver 2 2 Battery charger (350 mA maximum) Yes Yes ADC for battery voltage and Yes Yes temperature monitoring GPIO Up to 19 Up to 19 Multitone Yes Yes Integrated MPA and LPA Yes Yes
2.1 IS2083BM Device Ball Diagram
The following figure illustrates the ball diagram of the IS2083BM and IS2083BM-2L2. © 2019 Microchip Technology Inc.
Datasheet
DS70005403B-page 10 Document Outline Introduction Features Table of Contents 1. Quick References 1.1. Reference Documentation 1.2. Acronyms/Abbreviations 2. Device Overview 2.1. IS2083BM Device Ball Diagram 2.2. IS2083BM Device Ball Description 3. Audio Subsystem 3.1. Digital Signal Processor 3.2. Codec 3.2.1. Audio Performance 3.3. Auxiliary Port 3.4. Microphone Inputs 3.5. Analog Speaker Output 4. Bluetooth Transceiver 4.1. Transmitter 4.2. Receiver 4.3. Synthesizer 4.4. Modulator-Demodulator 4.5. Adaptive Frequency Hopping 5. Microcontroller 5.1. Memory 5.2. Clock 6. Power Management Unit 6.1. Device Operation 6.2. Power Supply 6.3. Adapter Input 6.4. Buck1 (BK1) Switching Regulator 6.5. Buck2 (BK2) Switching Regulator 6.6. Low-Droput Regulator 6.7. Battery Charging 6.7.1. Battery Charger Detection 6.8. SAR ADC 6.9. LED Driver 7. Application Information 7.1. Power On/Off Sequence 7.2. Reset 7.3. Programming and Debugging 7.3.1. Test Mode 7.3.2. Flash Memory and SQI Controller 7.3.2.1. SQI Controller 7.3.3. 2-wire Interface 7.3.3.1. Serial Program Clock 7.3.3.2. Serial Program Data 7.3.4. Enabling Programming Interface 7.3.5. On-chip Instrumentation 7.3.5.1. Enabling OCI Functionality 7.3.5.2. Entering Debug Mode 7.3.5.3. Reading the Debug Status 7.3.5.4. Reading the Program Counter 7.3.5.5. Stopping Program Execution (Entering Debug Mode) 7.3.5.6. Starting Program Execution (Exiting Debug Mode) 7.3.5.7. User Single Step Mode 7.3.5.8. OCI Single Step Mode 7.3.5.9. Setting Software Breakpoints 7.3.5.10. Simple and Complex Debug Triggers 7.3.5.11. Reading and Writing Memory/SFR Registers 7.3.5.12. Trace Buffer 7.3.5.13. Instruction Trace 7.4. General Purpose I/O Pins 7.5. I2S Mode Application 7.6. Host MCU Interface 8. Electrical Specifications 8.1. Timing Specifications 9. Package Information 10. Ordering Information 11. Document Revision History The Microchip Website Product Change Notification Service Customer Support Microchip Devices Code Protection Feature Legal Notice Trademarks Quality Management System Worldwide Sales and Service
