Product Breif Monarch NB02S (Sequans Communications)
ManufacturerSequans Communications
DescriptionEZLinkLTE Monarch NB02S Module. NB-IoT Module Enabling Next-generation 5G Massive IoT
Pages / Page2 / 1 — EZLinkLTE Monarch NB02S Module. Monarch N LTE Platform. Integrated …
File Format / SizePDF / 6.3 Mb
EZLinkLTE Monarch NB02S Module. Monarch N LTE Platform. Integrated Security and iSIM. Highlights. Applications
Product Breif Monarch NB02S Sequans Communications
NB-IoT Module Enabling Next-generation 5G Massive IoT The Monarch NB02S is an LTE Cat NB1/NB2 module based on Sequans’ second generation Monarch N chip platform. NB02S leverages Sequans’ 15-plus years of experience in 4G and 5G technologies and incorporates Sequans’ carrier-proven LTE protocol stack and a software suite that is one of the most mature in the industry. The NB02S is the first member of Sequans next generation “S” family of modules, featuring a very small yet cost-effective form factor that requires no external components. The NB02S inherits Monarch’s already certified NB-IoT stack and delivers the significantly improved performance and lower power consumption enabled by Sequans’ second generation Monarch N chip and the new module architecture. NB02S is a total module solution, including a complete, Single-SKU™ RF front end for deployment in any band worldwide, and an integrated EAL5+ Secure Element (SE) enabling the integration of the SIM inside the module with zero compromise on security while lowering cost and reducing complexity. Sequans technology, both hardware and software, is 100-percent owned by Sequans, ensuring fast time to market and lowest total cost of ownership for device makers.
Monarch N LTE Platform Integrated Security and iSIM Highlights
At the heart of NB02S is Monarch N, Sequans’ The secure element in Monarch N is Common • Supports 3GPP LTE Release 14/15 Cat NB1 second generation LTE Cat NB1/NB2 platform. Criteria EAL5+ certifiable and enables the iSIM and NB2 with up to 120.7 kbps DL and The new generation Monarch technology function to operate within the module with no 21 kbps UL improves on the size, cost, and power additional components, reducing operational • Tiny “S” series LGA module consumption of first-generation Monarch and complexity and cost for customers. The security • Single-rail power supply supporting includes new, powerful features such as an grade of the NB02S is the highest in the cellular 2.2-5.5 V allows for direct connection to EAL5+ Secure Element, usable as an iSIM, industry, enabling government-grade security low-cost batteries and a low-power MCU that is fully available for and allowing the provisioning of MNO or MVNO • Programmable RF filtering for global band running customer applications. The Monarch connectivity profiles in the module. Customers support in a Single-SKU™ design NB02S module is 5G-ready and designed to can also use the embedded Secure Element (617 MHz to 2.2 GHz) • enable massive IoT. for secure key storage and cryptographic Supports LTE bands 1, 2, 3, 4, 5, 8, 12, 13,14, 17, 18, 19, 20, 28, 66, 71, 85 operations at application level. •
Applications
Adaptive output power supporting
Ultra-low Power Consumption
+20dBm and +14dBm for efficient, deep The Monarch NB02S module is ideal for adding indoor penetration NB-IoT connectivity to low data rate M2M and The ultra-low power consumption of NB02S • Module-as-a-SIM™ -- Integrated connectivity IoT devices for wide deployment, including reflects the significant improvement in power in the module with no SIM card or SIM chip consumption of Sequans’ next generation required inside or outside the module utility meters, industrial sensors, asset trackers, Monarch N chip. Sequans’ proprietary Dynamic • and numerous additional smart home and Embedded LWM2M client, TCP/IP stack Power Management and eco-Paging™ and Sequans Cloud Connectors smart city devices. technologies adapt sleep and active state power • Fully tested and calibrated for easy consumption according to use case, enabling integration into product hardware
EZLinkLTE NB02S Evaluation Kit
10-15 years of battery life for some IoT use • Application MCU available for customer The NB02S evaluation kit enables world-wide cases. In addition, NB02S supports a single-rail applications connection to the cloud via NB-IoT networks power supply for a wide voltage range: 2.2V to • Fully software-compatible with first in minutes. The evaluation kit also includes a 5.5V. This allows a direct battery connection generation Monarch NB01Q module, schematic layout for reference and BOM enabling easy migration without the need of buck-boost or DC/DC design files for use in PCB designs. converters, enabling an NB02S design to be powered with 2 AA batteries. sequans.com
