CD453Absolute Maximum Ratings (Note 1) Recommended Operating (Note 2) Conditions (Note 2) 8BC DC Supply Voltage (VDD) −0.5 to +18 VDC DC Supply Voltage (VDD) 3 to 15 VDC Input Voltage (VIN) −0.5V to VDD + 0.5 VDC Input Voltage (VIN) 0 to VDD VDC Storage Temperature Range (TS) −65°C to +150°C Operating Temperature Range (TA) −55°C to +125°C Power Dissipation (P Note 1: “Absolute Maximum Ratings” are those values beyond which the D) safety of the device cannot be guaranteed, they are not meant to imply that Dual-In-Line 700 mW the devices should be operated at these limits. The tables of “Recom- mended Operating Conditions” and “Electrical Characteristics” provide con- Small Outline 500 mW ditions for actual device operation. Lead Temperature (TL) Note 2: VSS = 0V unless otherwise specified. (Soldering, 10 seconds) 260°C DC Electrical Characteristics (Note 2) − 55 ° C + 25 ° C + 125 ° CSymbolParameterConditionsUnitsMinMaxMinTypMaxMinMax IDD Quiescent VDD = 5V VIH = VDD 20 0.005 5 150 Device Current VDD = 10V VIL = VSS 40 0.010 10 300 µA VDD = 15V All Outputs Open 80 0.015 20 600 VOL LOW Level VDD = 5V |IO| < 1 µA 0.05 0 0.05 0.05 Output Voltage V V DD = 10V VIH = VDD, VIL = VSS 0.05 0 0.05 0.05 VDD = 15V 0.05 0 0.05 0.05 VOH HIGH Level VDD = 5V |IO| < 1 µA 4.95 4.95 5 4.95 Output Voltage V V DD = 10V VIH = VDD, VIL = VSS 9.95 9.95 10 9.95 VDD = 15V 14.95 14.95 15 14.95 VIL LOW Level |IO| < 1 µA Input Voltage VDD = 5V, VO = 0.5V or 4.5V 1.5 2.25 1.5 1.5 V V DD = 10V, VO = 1.0V or 9.0V 3.0 4.50 3.0 3.0 VDD = 15V, VO = 1.5V or 13.5V 4.0 6.75 4.0 4.0 VIH HIGH Level |IO| < 1 µA Input Voltage VDD = 5V, VO = 0.5V or 4.5V 3.5 3.5 2.75 3.5 V V DD = 10V, VO = 1.0V or 9.0V 7.0 7.0 5.50 7.0 VDD = 15V, VO = 1.5V or 13.5V 11.0 11.0 8.25 11.0 IOL LOW Level VDD = 5V, VO = 0.4V VIH = VDD 0.64 0.51 0.88 0.36 Output Current V mA DD = 10V, VO = 0.5V VIL = VSS 1.6 1.3 2.25 0.9 (Note 3) VD = 15V, VO = 1.5V 4.2 3.4 8.8 2.4 IOH HIGH Level VDD = 5V, VO = 4.6V −0.6 −0.51 −0.88 −0.36 Output Current V −1.6 −1.3 −2.25 −0.9 mA DD = 10V, VO = 9.5V VIL = VSS (Note 3) VD = 15V, VO = 13.5V −4.2 −3.4 −8.8 −2.4 IIN Input Current, VDD = 15V, VIN = 0V or 15V ±0.02 ±10−5 ±0.05 ±0.5 µA Pin 2 or 14 IIN Input Current VDD = 15V, VIN = 0V or 15V ±0.1 ±10−5 ±0.1 ±1.0 µA Other Inputs Note 3: IOH and IOL are tested one output at a time. 5 www.fairchildsemi.com
