Datasheet TC913A, TC913B (Microchip) - 3
ManufacturerMicrochip
DescriptionDual Auto-Zeroed Operational Amplifiers
Pages / Page14 / 3 — TC913A/TC913B. 1.0. ELECTRICAL CHARACTERISTICS. Absolute Maximum …
File Format / SizePDF / 194 Kb
TC913A/TC913B. 1.0. ELECTRICAL CHARACTERISTICS. Absolute Maximum Ratings*. TC913A AND TC913B ELECTRICAL SPECIFICATIONS
TC913A/TC913B 1.0 ELECTRICAL CHARACTERISTICS Absolute Maximum Ratings* TC913A AND TC913B ELECTRICAL SPECIFICATIONS
*Stresses above those listed under “Absolute Maximum Ratings” may cause permanent damage to
the device. These are stress ratings only and functional operation of the device at these or any other conditions Total Supply Voltage (VDD to VSS) ...+18V above those indicated in the operation sections of the Input Voltage .. (V - specifications is not implied. Exposure to Absolute DD +0.3V) to (VSS 0.3V) Maximum Rating conditions for extended periods may Current Into Any Pin... 10 mA affect device reliability. While Operating ... 100 A Package Power Dissipation (TA – 70°C) Plastic DIP ... 730 mW Plastic SOIC .. 470 mW Operating Temperature Range C Device .. 0°C to +70°C Storage Temperature Range .. -65°C to +150°C
TC913A AND TC913B ELECTRICAL SPECIFICATIONS Electrical Characteristics:
VS = ±5V, TA = +25°C, unless otherwise indicated.
TC913A TC913B Symbol Parameter Min Typ Max Min Typ Max Unit Test Conditions
VOS Input Offset — 5 15 — 15 30 V TA = +25°C Voltage TCV  OS Average Temp. — 0.05 0.15 — 0.1 0.25 V/°C 0°C  TA  +70°C Coefficient of — 0.05 0.15 — 0.1 0.25 V/°C -25°C  TA  +85°C Input Offset
(Note 1)
Voltage IB Average Input — — 90 — — 120 pA TA = +25°C Bias Current — — 3 — — 4 nA 0°C  TA  +70°C — — 4 — — 6 nA -25°C  TA  +85° IOS Average Input — 5 20 — 10 40 pA TA = +25°C Offset Current — — 1 — — 1 nA TA = +85°C e  N Input Voltage — 0.6 — — 0.6 — VP-P 0.1 to 1 Hz, RS  100 Noise — 11 — — 11 — VP-P 0.1 to 10 Hz, RS  100 CMRR Common Mode 110 116 — 100 110 — dB VSS  VCM  VDD - 2.2 Rejection Ratio CMVR Common Mode VSS — VDD - 2 VSS — VDD - 2 V Voltage Range AOL Open-Loop 115 120 — 110 120 — dB RL = 10 k, VOUT = ±4V Voltage Gain VOUT Output Voltage VSS + 0.3 — VDD - 0.9 VSS + 0.3 — VDD -0.9 V RL = 10 k Swing BW Closed Loop — 1.5 — — 1.5 — MHz Closed Loop Gain = +1 Bandwidth SR Slew Rate — 2.5 — — 2.5 — V/sec RL = 10 k, CL = 50 pF PSRR Power Supply 110 — — 100 — — dB ±3.3V to ±5.5V Rejection Ratio VS Operating ±3.5 — ±8.3 ±3.5 — ±8.3 V Split Supply Supply Voltage 7.0 — 16 7.0 — 16 V Single Supply Range IS Quiescent — 0.65 0.85 — — 1.1 mA VS = ±5V Supply Current
Note 1:
Characterized; not 100% tested.  2001-2012 Microchip Technology Inc. DS21482D-page 3 Document Outline TC913A/TC913B Features: Applications: Device Selection Table Package Type General Description: Functional Block Diagram 1.0 Electrical characteristics Absolute Maximum Ratings* tc913a and tc913b electrical specifications Note 1: Characterized; not 100% tested. 2.0 Pin Descriptions TABLE 2-1: Pin Function Table 3.0 Detailed Description 3.1 Theory of Operation 3.2 Pin Compatibility 3.3 Overload Recovery 3.4 Avoiding Latch-up 4.0 Typical Characteristics 5.0 packaging information 5.1 Package Marking Information 5.2 Taping Form 5.3 Package Dimensions 6.0 Revision History Notes: Dual Auto-Zeroed Operational Amplifiers The Microchip Web Site Customer Change Notification Service Customer Support Reader Response Corporate Office Atlanta Boston Chicago Cleveland Fax: 216-447-0643 Dallas Detroit Indianapolis Toronto Fax: 852-2401-3431 Australia - Sydney China - Beijing China - Shanghai India - Bangalore Korea - Daegu Korea - Seoul Singapore Taiwan - Taipei Fax: 43-7242-2244-393 Denmark - Copenhagen France - Paris Germany - Munich Italy - Milan Spain - Madrid UK - Wokingham Worldwide Sales and Service
