Datasheet PI4ULS5V202Q (Diodes) - 2
Manufacturer | Diodes |
Description | Automotive Qualified 2-BIT Bi-Directional Level Shifter With Automatic Sensing & Ultra Tiny Package |
Pages / Page | 10 / 2 — PI4ULS5V202Q. Block Diagram. Figure 1: Block Diagram Maximum Ratings. … |
PI4ULS5V202Q. Block Diagram. Figure 1: Block Diagram Maximum Ratings. Note:. Recommended Operation Conditions. Symbol. Parameter. Min
PI4ULS5V202Q Block Diagram Figure 1: Block Diagram Maximum Ratings Note:
Storage Temperature ... -65oC to +150oC Stresses greater than those listed under MAXIMUM Junction Temperature ... 125 oC RATINGS may cause permanent damage to the DC Supply Voltage port B .. -0.3V to +5.5V device. This is a stress rating only and functional DC Supply Voltage port A .. -0.3V to+5.5V operation of the device at these or any other Vi(A) referenced DC Input / Output Voltage.. -0.3V to +5.5V conditions above those indicated in the operational sections of this specification is not implied. Vi(B) referenced DC Input / Output Voltage ... -0.3V to+5.5V Exposure to absolute maximum rating conditions Enable Control Pin DC Input Voltage ... -0.3V to+5.5V for extended periods may affect reliability. Short Circuit Duration (I/O to GND) ... 40mA
Recommended Operation Conditions Symbol Parameter Min Typ Max Unit
VCCA VCCA Positive DC Supply Voltage 1.2 - 5.5 V VCCB VCCB Positive DC Supply Voltage 1.2 - 5.5 V VEN Enable Control Pin Voltage GND - 5.5 V VIO I/O Pin Voltage GND - 5.5 V TA Operating Temperature Range −40 - +125 °C PI4ULS5V202Q
www.diodes.com
July 2019 Document Number DS41479 Rev 2-2 2 © Diodes Incorporated
