Datasheet MAX16160 (Maxim) - 8
ManufacturerMaxim
DescriptionHigh-Accuracy 4-Channel, Any-Input Supervisory Circuits
Pages / Page17 / 8 — Pin Description (continued). PIN. NAME. FUNCTION. 6 SOT23. 6 WLP
File Format / SizePDF / 529 Kb
Pin Description (continued) PIN NAME FUNCTION 6 SOT23 6 WLP
MAX16160 High-Accuracy 4-Channel, Any-Input Supervisory Circuits
Monitoring Input 3. When Input 3 has an internally fixed trip threshold, connect directly to the supply voltage to be monitored. When Input 3 is an adjustable input, connect to the 3 B3 IN3 supply voltage to be monitored through a resistive divider network. For better immunity to external noise, place a 0.1µF capacitor between IN3 and GND as close as possible to the MAX16060. Monitoring Input 4. When Input 4 has an internally fixed trip threshold, connect directly to the supply voltage to be monitored. When Input 4 is an adjustable input, connect to the 4 A3 IN4 supply voltage to be monitored through a resistive divider network. For better immunity to external noise, place a 0.1µF capacitor between IN4 and GND as close as possible to the MAX16060. 5 A2 GND Ground Active-Low, Open-Drain Reset Output. RESET asserts low when any input falls below its 6 A1 RESET set threshold. RESET deasserts after the reset timeout period when all inputs rise above their set thresholds. RESET has a weak (18μA) internal pullup to IN2/VCC. www.maximintegrated.com Maxim Integrated | 8 Document Outline General Description Applications Benefits and Features Typical Operating Circuit Absolute Maximum Ratings Package Information 6 SOT23 6 WLP Electrical Characteristics Typical Operating Characteristics Typical Operating Characteristics (continued) Pin Configurations 6 SOT23 6 WLP Pin Description Pin Description (continued) Block Diagrams Internally Fixed Threshold Block Diagrams (continued) Adjustable Threshold Detailed Description Reset Output Input Hysteresis Input Thresholds Applications Information Adjustable Threshold Inputs (IN1, IN3, IN4) Adding Manual Reset Capability Unused Inputs Power-Supply Bypassing Selector Guide Typical Application Circuit Ordering Information Revision History
