Datasheet 2SC5200 (Toshiba)
ManufacturerToshiba
DescriptionSilicon NPN Triple Diffused Type
Pages / Page5 / 1 — 2SC5200. Absolute Maximum Ratings (Ta = 25°C)
File Format / SizePDF / 208 Kb
Datasheet 2SC5200 Toshiba
2SC5200 TOSHIBA Transistor Silicon NPN Triple Diffused Type
2SC5200
Power Amplifier Applications Unit: mm • High breakdown voltage: VCEO = 230 V (min) • Complementary to 2SA1943 • Suitable for use in 100-W high fidelity audio amplifier’s output stage
Characteristics Symbol Rating Unit Collector-base voltage VCBO 230 V Collector-emitter voltage VCEO 230 V Emitter-base voltage VEBO 5 V Collector current IC 15 A Base current IB 1.5 A Collector power dissipation P C 150 W (Tc = 25°C) JEDEC ― Junction temperature Tj 150 °C JEITA ― Storage temperature range Tstg − 55 to 150 °C TOSHIBA 2-21F1A Note: Using continuously under heavy loads (e.g. the application of high Weight: 9.75 g (typ.) temperature/current/voltage and the significant change in temperature, etc.) may cause this product to decrease in the reliability significantly even if the operating conditions (i.e. operating temperature/current/voltage, etc.) are within the absolute maximum ratings. Please design the appropriate reliability upon reviewing the Toshiba Semiconductor Reliability Handbook (“Handling Precautions”/"Derating Concept and Methods") and individual reliability data (i.e. reliability test report and estimated failure rate, etc). Start of commercial production 1994-09 1 2016-01-07
