Datasheet U2010B (Atmel)
ManufacturerAtmel
DescriptionPhase-control IC with Current Feedback and Overload Protection
Pages / Page19 / 1 — Features. Full-wave Current Sensing. Mains Supply Variation Compensated
Datasheet U2010B Atmel
Features
Programmable Load-current Limitation with Over- and High-load Output
Variable Soft Start
Voltage and Current Synchronization
Automatic Retriggering Switchable
Triggering Pulse Typically 125mA
Internal Supply-voltage Monitoring
Current Requirement
3mA Phase-control
Temperature-compensated Reference Voltage IC with Current Applications Feedback and
Advanced Motor Control
Overload Grinder
Drilling Machine Protection 1. Description
The U2010B is designed as a phase-control circuit in bipolar technology for motor
Atmel U2010B
control applications with load-current feedback and overload protection. It enables load-current detection and has a soft-start function as well as reference voltage output.
Figure 1-1.
Block Diagram 15 14 13 12 11 Overload Limiting Voltage Mains voltage Supply 10 detector detector compensation voltage High load GND Automatic A 100% 70% retriggering αmax Output B 9 Phase Programmable Auto- Current control unit overload start - 1 2 + detector protection ϕ = f(V4) Full wave C I rectifier max 16 Voltage
Atmel
monitoring
U2010B
1 Load current Level Soft Reference detector shift start voltage 2 3 4 5 6 7 8 4766D–INDCO–03/11 Document Outline Features Applications 1. Description 2. Pin Configuration 3. General Description 3.1 Mains Supply 3.2 Voltage Monitoring 3.3 Phase Control 3.4 Automatic Retriggering 3.5 Current Synchronization 3.6 Voltage Synchronization with Mains Voltage Compensation 3.7 Load-current Compensation 3.8 Load-current Limitation 3.8.1 Mode Selection 4. Absolute Maximum Ratings 5. Thermal Resistance 6. Electrical Characteristics 7. Diagrams 8. Ordering Information 9. Package Information 10. Revision History
