Datasheet SIC466, SiC467, SiC468, SiC469 (Vishay) - 5
ManufacturerVishay
Description4.5 V to 60 V Input, 2 A, 4 A, 6 A, 10 A microBUCK DC/DC Converter
Pages / Page24 / 5 — SiC466, SiC467, SiC468, SiC469. ELECTRICAL SPECIFICATIONS. PARAMETER …
File Format / SizePDF / 955 Kb
SiC466, SiC467, SiC468, SiC469. ELECTRICAL SPECIFICATIONS. PARAMETER SYMBOL. TEST. CONDITIONS. MIN. TYP. MAX. UNIT. Fault Protections
SiC466, SiC467, SiC468, SiC469 ELECTRICAL SPECIFICATIONS PARAMETER SYMBOL TEST CONDITIONS MIN TYP MAX UNIT Fault Protections
(VIN = VCIN = 48 V, TJ = -40 °C to +125 °C, unless otherwise stated)
PARAMETER SYMBOL TEST CONDITIONS MIN. TYP. MAX. UNIT Fault Protections
ILM tied to VDD - 13 - SiC466 valley current limit ILM is not connect - 9.75 - ILM tied to AGND - 6.5 - ILM tied to VDD - 10 - SiC467 valley current limit ILM is not connect - 7.5 - ILM tied to AGND - 5 - IOCP A ILM tied to VDD - 6 - SiC468 valley current limit ILM is not connect - 4.2 - ILM tied to AGND - 3 - ILM tied to VDD - 4 - SiC469 valley current limit ILM is not connect - 3 - ILM tied to AGND - 2 - Output OVP threshold OVP - 20 - VFB with respect to 0.8 V reference % Output UVP threshold UVP - -80 - OTPR Rising temperature - 150 - Over temperature protection °C OTPHYST Hysteresis - 35 -
Power Good
VFB_RISING_VTH_OV VFB rising above 0.8 V reference - 20 - Power good output threshold % VFB_FALLING_VTH_UV VFB falling below 0.8 V reference - -10 - Power good hysteresis PGOOD_HYST 30 40 55 mV Power good on resistance RON_PGOOD - 6 15 Power good delay time tDLY_PGOOD 15 25 35 μs
EN / MODE / Threshold
EN logic high level VEN_H 1.2 1.4 1.5 V EN logic low level VEN_L 1 1.2 1.35 EN logic hysteresis VEN_HYS 150 200 400 mV EN pull down resistance REN - 6 - M Mode pull up current IMODE - 5 - μA Power save mode enabled, V Mode 1 DD, VDRV - 2 - Pre-reg on Power save mode disabled, V Mode 2 DD, VDRV - 301 - Pre-reg on RMODE k Power save mode disabled, V Mode 3 DRV Pre-reg - 499 - off, VDD Pre-reg on, provide external VDRV Power save mode enabled, V Mode 4 DRV Pre-reg off, - 1000 - VDD Pre-reg on, provide external VDRV
Note
(1) Guaranteed by design S19-0911-Rev. E, 28-Oct-2019
5
Document Number: 76044 For technical questions, contact: powerictechsupport@vishay.com THIS DOCUMENT IS SUBJECT TO CHANGE WITHOUT NOTICE. THE PRODUCTS DESCRIBED HEREIN AND THIS DOCUMENT ARE SUBJECT TO SPECIFIC DISCLAIMERS, SET FORTH AT www.vishay.com/doc?91000
