Datasheet 48L512, 48LM01 (Microchip) - 10
ManufacturerMicrochip
Description512-Kbit/1-Mbit SPI Serial EERAM
Pages / Page40 / 10 — 48L512/48LM01. 4.0. FUNCTIONAL DESCRIPTION. FIGURE 4-1:. SPI MODE 0 AND …
File Format / SizePDF / 648 Kb
48L512/48LM01. 4.0. FUNCTIONAL DESCRIPTION. FIGURE 4-1:. SPI MODE 0 AND MODE 3. 4.1. Interfacing the 48L512/48LM01 on. the SPI Bus
48L512/48LM01 4.0 FUNCTIONAL DESCRIPTION FIGURE 4-1: SPI MODE 0 AND MODE 3 4.1 Interfacing the 48L512/48LM01 on the SPI Bus
link to page 14 link to page 14
The 48L512/48LM01 supports the two most common modes, SPI Modes 0 and 3. With SPI Modes 0 and 3, The 48L512/48LM01 is controlled by a set of data is always latched in on the rising edge of SCK instructions that are sent from a host controller, and always output on the falling edge of SCK. The commonly referred to as the SPI Master. The SPI only difference between SPI Modes 0 and 3 is the Master communicates with the 48L512/48LM01 via the polarity of the SCK signal when in the inactive state SPI bus which is comprised of four signal lines: (when the SPI Master is in Standby mode and not • Chip Select (CS) transferring any data). SPI Mode 0 is defined as a low • Serial Clock (SCK) SCK while CS is not asserted (high) and SPI Mode 3 has SCK high in the inactive state. The SCK Idle state • Serial Input (SI) must match when the CS is deasserted both before • Serial Output (SO) and after the communication sequence in SPI Mode 0 The SPI protocol defines a total of four modes of and 3. operation (Mode 0, 1, 2, or 3) with each mode differing The figures in this document depict Mode 0 with a in respect to the SCK polarity and phase and how the solid line on SCK while CS is inactive and Mode 3 with polarity and phase control the flow of data on the SPI a dotted line. bus.
CS Mode 3 Mode 3 SCK Mode 0 Mode 0 SI MSb LSb SO MSb LSb
4.1.2 SENDING DATA TO THE DEVICE
the SPI Bus
The 48L512/48LM01 uses the Serial Data Input (SI) pin to receive information. All instructions, addresses, and Communication to and from the 48L512/48LM01 must data input bytes are clocked into the device with the be initiated by the SPI Master device. The SPI Master device must generate the serial clock for the Most Significant bit (MSb) first. 48L512/48LM01 on the SCK pin. The 48L512/48LM01 The SI pin samples on the first rising edge of the SCK always operates as a slave due to the fact that the line after the CS has been asserted. Serial Clock pin (SCK) is always an input. 4.1.3 RECEIVING DATA FROM THE 4.1.1 SELECTING THE DEVICE DEVICE The 48L512/48LM01 is selected when the CS pin is Data output from the device is transmitted on the Serial low. When the device is not selected, data will not be Data Output (SO) pin with the MSb output first. The SO accepted via the SI pin and the SO pin wil remain in a data is latched on the falling edge of the first SCK clock high-impedance state. cycle after the instruction has been clocked into the device, such as the Read from Memory Array and Read STATUS Register instructions. See
Section 6.0 "STATUS Register"
for more details.  2018-2019 Microchip Technology Inc. DS20006008C-page 10 Document Outline Serial SRAM Features Hidden EEPROM Backup Features Other Features of the 48L512/48LM01 Packages Package Types (not to scale) Pin Function Table General Description Block Diagram Normal Device Operation Vcc Power-Off Event 1.0 Electrical Characteristics Absolute Maximum Ratings† TABLE 1-1: DC Characteristics TABLE 1-2: AC Characteristics TABLE 1-3: AC Test Conditions 2.0 Pin Descriptions TABLE 2-1: Pin Function Table 2.1 Chip Select (CS) 2.2 Serial Output (SO) 2.3 Serial Input (SI) 2.4 Serial Clock (SCK) 2.5 Hold (HOLD) 3.0 Memory Organization 3.1 Data Array Organization 3.2 16-Byte Nonvolatile User Space 3.3 Device Registers 3.3.1 STATUS Register 4.0 Functional Description FIGURE 4-1: SPI Mode 0 and Mode 3 4.1 Interfacing the 48L512/48LM01 on the SPI Bus 4.1.1 Selecting the Device 4.1.2 Sending Data to the Device 4.1.3 Receiving Data from the Device 4.2 Device Opcodes 4.2.1 Serial Opcode 4.2.2 Hold Function FIGURE 4-2: Hold Mode 5.0 Write Enable and Disable 5.1 Write Enable Instruction (WREN) FIGURE 5-1: WREN Waveform 5.2 Write Disable Instruction (WRDI) FIGURE 5-2: WRDI Waveform 6.0 STATUS Register 6.1 Block Write-Protect Bits TABLE 6-2: Block Write-Protect Bits 6.2 Write Enable Latch 6.3 Ready/Busy Status Latch 6.4 Read STATUS Register (RDSR) FIGURE 6-1: RDSR Waveform 6.5 Write STATUS Register (WRSR) FIGURE 6-2: WRSR Waveform 7.0 Read Operations 7.1 Reading from the SRAM (READ) FIGURE 7-1: Read SRAM (READ) Waveform 8.0 Write Commands 8.1 Write Instruction Sequences 8.1.1 SRAM Byte Write FIGURE 8-1: SRAM Byte Write Waveform 8.1.2 Continuous Write FIGURE 8-2: Continuous SRAM Write Waveform 9.0 Nonvolatile User Space Access 9.1 Write Nonvolatile User Space (WRNUR) 9.2 Read Nonvolatile User Space (RDNUR) 10.0 Secure Operations 10.1 Secure Write 10.2 Secure Read TABLE 10-1: Secure Write Bits 11.0 Store/Recall Operations 11.1 Automatic Store on Any Power Disruption 11.2 Automatic Recall to SRAM 11.3 Software Store Command FIGURE 11-1: Software Store 11.4 Software Recall Command FIGURE 11-2: Software Recall 11.5 Polling Routine FIGURE 11-3: Polling Flow FIGURE 11-4: AutoStore/AutoRecall Scenarios (with ASE = 0, Array Modified) FIGURE 11-5: AutoStore/AutoRecall Scenarios (with ASE = 1 or Array Not Modified) 12.0 Hibernation FIGURE 12-1: Hibernate Waveform 13.0 Trip Voltage 13.1 Power Switchover 14.0 Packaging Information 14.1 Package Marking Information Appendix A: Revision History Product ID System Trademarks Worldwide Sales
