Datasheet AL8862Q (Diodes) - 5
Manufacturer | Diodes |
Description | Automotive Grade 55V 1A Step-Down Converter |
Pages / Page | 16 / 5 — AL8862Q. Typical Performance Characteristics. Quiescent Current v. s. … |
File Format / Size | PDF / 995 Kb |
AL8862Q. Typical Performance Characteristics. Quiescent Current v. s. Input Voltage Quiescent Current. vs. Temperature
AL8862Q Typical Performance Characteristics
(TA = +25°C, VIN = 16V, unless otherwise noted).
Quiescent Current v s. Input Voltage Quiescent Current vs. Temperature
420 480 418 470 460 416 450 414 440 412 A) 430 410 A) t ( n t ( 420 n 408 rre 410 u rre 406 u 400 t C 404 n t C 390 n 402 sce 380 ie 400 sce u 370 ie Q 398 u 360 Q V =16V IN 396 350 394 340 392 330 390 320 3 6 9 12 15 18 21 24 27 30 33 36 39 42 45 48 51 54 57 60 -50 -40 -30 -20 -10 0 10 20 30 40 50 60 70 80 90 100 110 120 130 Input Voltage (V) Temperature (OC)
SET Threshold Voltag e vs. Input voltage SET Threshold Voltage vs. Temperature
120 120 115 115 110 110 105 105 (mV) (mV) e 100 100 g e g lta 95 at 95 l Vo 90 Vo 90 ld d o l 85 o sh 85 sh re h 80 re 80 T h T 75 75 VTH_H V SET TH_H 70 V SET 70 TH_MEAN V TH_MEAN 65 V 65 TH_L V TH_L 60 60 3 6 9 12 15 18 21 24 27 30 33 36 39 42 45 48 51 54 57 60 -50 -40 -30 -20 -10 0 10 20 30 40 50 60 70 80 90 100 110 120 130 Input Voltage (V) Temperature (OC)
PWM Dimming (VIN=16V, 3LEDs, 68μH, RS=0.3Ω) Analog Dimming (VIN=16V, 3LEDs, 47μH, RS=0.3Ω) Output Current vs. Duty Cycle LED Current vs . CTRL Pin Voltage
340 360 320 340 f =100Hz 300 PWM 320 280 f =500Hz 300 PWM 260 f =1kHz 280 PWM 240 260 f =10kHz 220 PWM 240 (mA) t 220 200 t (mA) n n 200 180 rre rre u 180 160 u C t 160 140 t C u u p 140 120 t tp u 120 u 100 O O 100 80 80 60 60 40 40 20 20 0 0 0 10 20 30 40 50 60 70 80 90 100 0.2 0.4 0.6 0.8 1.0 1.2 1.4 1.6 1.8 2.0 2.2 2.4 2.6 Duty Cycle (%) CTRL Pi n Voltage (V) AL8862Q 5 of 16 December 2019 Document number: DS42199 Rev. 3 - 2
www.diodes.com
© Diodes Incorporated
