Datasheet BCR430UW6 (Diodes)
Manufacturer | Diodes |
Description | Low Dropout Voltage Linear LED Driver Ic In SOT26 |
Pages / Page | 9 / 1 — BCR430UW6. LOW DROPOUT VOLTAGE LINEAR LED DRIVER IC IN SOT26. … |
File Format / Size | PDF / 682 Kb |
BCR430UW6. LOW DROPOUT VOLTAGE LINEAR LED DRIVER IC IN SOT26. Description. Features
BCR430UW6 LOW DROPOUT VOLTAGE LINEAR LED DRIVER IC IN SOT26 Description Features
The BCR430U is a monolithically integrated linear LED controller LED Current Tolerance of ±5% at 95mA Output Current designed to function as a Constant Current Regulator (CCR) for linear Thermal Protection Reduces LED Current at Elevated LED driving. The device operates over a voltage range from 5V to Temperature 42V and regulates the output LED current up to 100mA, set by an Low Typical Saturation Voltage of 115mV at 50mA external resistor. It is designed for driving LEDs in strings and will 5mA to 100mA Adjustable LED Current with an External Resistor reduce current at increasing temperatures to self-protect. The low 5V to 42V Supply Voltage voltage drop during current regulation allows efficient driving of LED High Power 1W Dissipation in SOT26 strings with a range of forward voltages and supply voltage No External Capacitors Required for Stable Operation tolerances. LED Dimming Using PWM Parallel Devices to Increase Regulated Current
Totally Lead-Free & Fully RoHS Compliant (Notes 1 & 2) Applications Halogen and Antimony Free. “Green” Device (Note 3)
LED Strips
For automotive applications requiring specific change control
LED Panel Displays
(i.e. parts qualified to AEC-Q101, PPAP capable, and
Architectural and Landscape Lighting
manufactured in IATF 16949 certified facilities), please
Mood and Decorative Lighting
contact us or your local Diodes representative.
Retail Lighting
https://www.diodes.com/quality/product-definitions/ Mechanical Data
Case: SOT26 Case Material: Molded Plastic. “Green” Molding Compound. UL Flammability Rating 94V-0 Moisture Sensitivity: Level 1 per J-STD-020 Terminals: Finish - Matte Tin Plated Leads. Solderable per MIL-STD-202, Method 208 Weight: 0.018 grams (Approximate) SOT26 Typical Configuration
Ordering Information
(Note 4)
Product Marking Reel Size (inches) Tape Width (mm) Quantity per Reel
BCR430UW6-7 430 7 8 3,000 Notes: 1. No purposely added lead. Fully EU Directive 2002/95/EC (RoHS), 2011/65/EU (RoHS 2) & 2015/863/EU (RoHS 3) compliant. 2. See https://www.diodes.com/quality/lead-free/ for more information about Diodes Incorporated’s definitions of Halogen- and Antimony-free, "Green" and Lead-free. 3. Halogen- and Antimony-free "Green” products are defined as those which contain <900ppm bromine, <900ppm chlorine (<1500ppm total Br + Cl) and <1000ppm antimony compounds. 4. For packaging details, go to our website at https://www.diodes.com/design/support/packaging/diodes-packaging/. BCR430UW6 1 of 9 October 2019 Datasheet number: DS42214 Rev. 2 - 2
www.diodes.com
© Diodes Incorporated
