Datasheet HCPL-181 (Broadcom) - 4
ManufacturerBroadcom
DescriptionPhototransistor Optocoupler SMD Mini-Flat Type
Pages / Page8 / 4 — HCPL-181. Absolute Maximum Ratings (TA = 25°C). Description. Value. Rank …
File Format / SizePDF / 828 Kb
HCPL-181. Absolute Maximum Ratings (TA = 25°C). Description. Value. Rank Mark. CTR (%). Conditions
HCPL-181 Absolute Maximum Ratings (TA = 25°C) Description Value Rank Mark CTR (%) Conditions
HCPL-181
Data Sheet Phototransistor Optocoupler SMD Mini-Flat Type
Storage Temperature, TS –55°C to +155°C A 80 ~ 160 IF = 5 mA, VCE = 5 V, TA = 25°C Operating Temperature, TA –55°C to +100°C B 130 ~ 260 Lead Solder Temperature, maximum 260°C for 10s C 200 ~ 400 (1.6 mm below seating plane) D 300 ~ 600 Average Forward Current, IF 50 mA Reverse Input Voltage, VR 6V Input Power Dissipation, PI 70 mW Collector Current, IC 50 mA Collector-Emitter Voltage, VCEO 80V Emitter-Collector Voltage, VECO 6V Collector Power Dissipation 150 mW Total Power Dissipation 170 mW Isolation Voltage, Viso 3750 Vrms (AC for 1 minute, R.H. = 40% ~ 60%)
Electrical Specifications (TA = 25°C) Parameter Symbol Min. Typ. Max. Units Test Conditions
Forward Voltage VF — 1.2 1.4 V IF = 20 mA Reverse Current IR — — 10 µA VR = 4V Terminal Capacitance Ct — 30 250 pF V = 0, f = 1 kHz Collector Dark Current ICEO — — 100 nA VCE = 20V Collector-Emitter Breakdown Voltage BVCEO 80 — — V IC = 0.1 mA, IF = 0 Emitter-Collector Breakdown Voltage BVECO 6 — — V IE = 10 µA, IF = 0 Collector Current IC 2.5 — 30 mA IF = 5 mA, VCE = 5V Current Transfer Ratioa CTR 50 — 600 % Collector-Emitter Saturation Voltage VCE(sat) — — 0.2 V IF = 20 mA, IC = 1 mA Response Time (Rise) tr — 4 18 µs VCC = 2V, IC = 2 mA Response Time (Fall) tf — 3 18 µs RL = 100Ω Isolation Resistance Riso 5 × 1010 1 × 1011 — Ω DC 500V, 40% ~ 60% RH Floating Capacitance Cf — 0.6 1.0 pF V = 0, f = 1 MHz a. CTR = (IC / IF) × 100%. Broadcom AV02-0774EN 4 Document Outline Description Schematic Functional Diagram Features Applications Ordering Information Package Outline Drawings HCPL-181-000E HCPL-181-060E Solder Reflow Temperature Profile Absolute Maximum Ratings (TA = 25°C) Electrical Specifications (TA = 25°C) Test Circuit for Response Time Test Circuit for Frequency Response
