Datasheet AD8218 (Analog Devices) - 4
DescriptionZero Drift, Bi-Directional Current Shunt Monitor
Pages / Page16 / 4 — AD8218. Data Sheet. ABSOLUTE MAXIMUM RATINGS. Table 2. Parameter. Rating. …
File Format / SizePDF / 363 Kb
AD8218. Data Sheet. ABSOLUTE MAXIMUM RATINGS. Table 2. Parameter. Rating. ESD CAUTION
AD8218 Data Sheet ABSOLUTE MAXIMUM RATINGS Table 2 Parameter Rating ESD CAUTION
AD8218 Data Sheet ABSOLUTE MAXIMUM RATINGS Table 2. Parameter Rating
Stresses above those listed under Absolute Maximum Ratings Maximum Input Voltage ( +IN, −IN to GND) −0.3 V to +85 V may cause permanent damage to the device. This is a stress Differential Input Voltage (+IN to –IN) ±5 V rating only; functional operation of the device at these or any Human Body Model (HBM) ESD Rating ±2000 V other conditions above those indicated in the operational Operating Temperature Range (T section of this specification is not implied. Exposure to absolute OPR) −40°C to +125°C Storage Temperature Range −65°C to +150°C maximum rating conditions for extended periods may affect Output Short-Circuit Duration Indefinite device reliability.
ESD CAUTION
Rev. B | Page 4 of 16 Document Outline Features Applications Functional Block Diagram General Description Table of Contents Revision History Specifications Absolute Maximum Ratings ESD Caution Pin Configurations and Function Descriptions Typical Performance Characteristics Theory of Operation Amplifier Core Output Clamping Application Notes Supply (VS) Connections Enable Pin (ENB) Operation Applications Information Unidirectional High-Side Current Sensing Bidirectional High-Side Current Sensing Motor Control Current Sensing Outline Dimensions Ordering Guide
