Datasheet AD8217 (Analog Devices) - 6
Description | High Resolution, Zero-Drift Current Shunt Monitor |
Pages / Page | 16 / 6 — AD8217. TYPICAL PERFORMANCE CHARACTERISTICS. d 18. V) (µ I. UDE 15. G 12. … |
Revision | A |
File Format / Size | PDF / 325 Kb |
AD8217. TYPICAL PERFORMANCE CHARACTERISTICS. d 18. V) (µ I. UDE 15. G 12. A M. –40. –20. 100. 120. 140. 10k. 100k. FREQUENCY (Hz). TEMPERATURE (°C)
AD8217 TYPICAL PERFORMANCE CHARACTERISTICS 40 30 27 38 24 36 21 B) 34 d 18 ( V) (µ I 32 UDE 15 IT OS N V G 12 30 A M 9 28 6 26 3 24 0 –40 –20 0 20 40 60 80 100 120 140
3
1k 10k 100k 1M
06 0 -00 1-
FREQUENCY (Hz)
16
TEMPERATURE (°C)
61 91 09 0 Figure 3. Typical Input Offset vs. Temperature Figure 6. Typical Small-Signal Bandwidth (VOUT = 200 mV p-p)
140 10 9 130 8 7 120 ) % 6 R ( 110 5 RRO 4 B) d 100 E ( 3 UT RR P 2 90 CM UT 1 –40°C O 80 +25°C L 0 A +125°C T O –1 70 T –2 –3 60 –4 50 –5
07
100 1000 10k 100k 1M
04
0 5 10 15 20 25 30 35 40 45 50
0 0 1- 1-
DIFFERENTIAL INPUT (mV)
16
FREQUENCY (Hz)
16 09 09 Figure 4. Typical CMRR vs. Frequency Figure 7. Total Output Error vs. Differential Input Voltage
500 800 450 700 +IN 400 600 A) µ ) ( T pm 350 N 500 p ( R O URRE 300 R 400 R C E AS IN 250 300 BI T GA U 200 200 INP 150 100 –IN 100 0
05 8
0
0 5 10 15 20 25 30 35 40 45 50 55 60 65 70 75 80
00 1- 1- 16
TEMPERATURE (°C) INPUT COMMON-MODE VOLTAGE (V)
16 09 09 Figure 5. Typical Gain Error vs. Temperature Figure 8. Input Bias Current vs. Input Common-Mode Voltage (Differential Input Voltage = 5 mV) Rev. A | Page 6 of 16 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION AMPLIFIER CORE INTERNAL LDO APPLICATION NOTES OUTPUT LINEARITY APPLICATIONS INFORMATION HIGH-SIDE CURRENT SENSING MOTOR CONTROL CURRENT SENSING OUTLINE DIMENSIONS ORDERING GUIDE
