13 /7 — Data Sheet. AD8215. 120. 110. 100. A) µ. 100mV/DIV. INPUT. T N. RRE. IN+. …
Revision
B
PDF / 258 Kb
Data Sheet. AD8215. 120. 110. 100. A) µ. 100mV/DIV. INPUT. T N. RRE. IN+. 1V/DIV. BI UT. IN–. OUTPUT. INP. 125. 150. 175. 200. 225. 250. TIME (400ns/DIV)
Data SheetAD8215120110100A) µ100mV/DIV(INPUTT N190RREIN+80CU1V/DIVAS70BI UTIN–OUTPUT602INP50 2 01 3- 20 07 400255075100125150175200225250 6 TIME (400ns/DIV) -00 03 DIFFERENTIAL INPUT VOLTAGE (mV) 72 0 Figure 10. Input Bias Current vs. Differential Input Voltage, V Figure 13. Fall Time CM = 5 V 0.80.4INPUT0A) m (100mV/DIV1NT –0.4EOUTPUT–0.8CURRIAS –1.2B UT1V/DIVP2–1.6IN–2.0 15 0 3- 20 07 –2.4–4–20246865 4 TIME (400ns/DIV) -00 03 INPUT COMMON-MODE VOLTAGE (V) 72 0 Figure 11. Input Bias Current vs. Input Common-Mode Voltage Figure 14. Rise Time 4.0200mV/DIV3.5A)INPUT3.0(m1NT E2.52V/DIVCURR Y L P2.0P U S1.5OUTPUT2 13 0 3- 20 07 1.0–4–20246865 05 TIME (1µs/DIV) 0 3- 20 INPUT COMMON-MODE VOLTAGE (V) 07 Figure 12. Supply Current vs. Input Common-Mode Voltage Figure 15. Differential Overload Recovery (Falling) Rev. B | Page 7 of 13 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION APPLICATION NOTES OUTPUT LINEARITY APPLICATIONS INFORMATION HIGH-SIDE CURRENT SENSING WITH A LOW-SIDE SWITCH HIGH-SIDE CURRENT SENSING LOW-SIDE CURRENT SENSING OUTLINE DIMENSIONS ORDERING GUIDE AUTOMOTIVE PRODUCTS
