Datasheet AD8211 (Analog Devices) - 4
DescriptionHigh Voltage, Current Shunt Monitor
Pages / Page13 / 4 — AD8211. Data Sheet. ABSOLUTE MAXIMUM RATINGS. ESD CAUTION. Table 2. …
RevisionC
File Format / SizePDF / 352 Kb
AD8211. Data Sheet. ABSOLUTE MAXIMUM RATINGS. ESD CAUTION. Table 2. Parameter. Rating
AD8211 Data Sheet ABSOLUTE MAXIMUM RATINGS ESD CAUTION Table 2 Parameter Rating
AD8211 Data Sheet ABSOLUTE MAXIMUM RATINGS ESD CAUTION Table 2. Parameter Rating
Supply Voltage 12.5 V Continuous Input Voltage Range −3 V to +68 V Reverse Supply Voltage −0.3 V Differential Input Voltage ±500 mV ESD Rating Human Body Model (HBM) ±4000 V Charged Device Model (CDM) ±1000 V Operating Temperature Range −40°C to +125°C Storage Temperature Range −65°C to +150°C Stresses at or above those listed under Absolute Maximum Ratings may cause permanent damage to the product. This is a stress rating only; functional operation of the product at these or any other conditions above those indicated in the operational section of this specification is not implied. Operation beyond the maximum operating conditions for extended periods may affect product reliability. Rev. C | Page 4 of 13 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION APPLICATION NOTES OUTPUT LINEARITY APPLICATIONS INFORMATION HIGH-SIDE CURRENT SENSE WITH A LOW-SIDE SWITCH HIGH-SIDE CURRENT SENSING LOW-SIDE CURRENT SENSING OUTLINE DIMENSIONS ORDERING GUIDE AUTOMOTIVE PRODUCTS
