Datasheet AD8214 (Analog Devices) - 5
DescriptionFast Response, High Voltage, Current Shunt Comparator
Pages / Page16 / 5 — Data Sheet. AD8214. PIN CONFIGURATION AND FUNCTION DESCRIPTIONS. VS 1. …
RevisionA
File Format / SizePDF / 247 Kb
Data Sheet. AD8214. PIN CONFIGURATION AND FUNCTION DESCRIPTIONS. VS 1. –IN. +IN. TOP VIEW. (Not to Scale). VREG 3. GND. OUT. NC = NO CONNECT
Data Sheet AD8214 PIN CONFIGURATION AND FUNCTION DESCRIPTIONS VS 1 –IN +IN TOP VIEW (Not to Scale) VREG 3 GND OUT NC = NO CONNECT
Data Sheet AD8214 PIN CONFIGURATION AND FUNCTION DESCRIPTIONS 1 6 8 VS 1 AD8214 8 –IN 2 +IN 2 TOP VIEW 7 NC (Not to Scale) VREG 3 6 GND 3 5 NC 4 5 OUT
007 002
NC = NO CONNECT
06193- 06193- Figure 2. Metallization Diagram Figure 3. Pin Configuration
Table 3. Pin Function Descriptions Pin No. Mnemonic X Y Description
1 VS –196 +447 Supply Voltage. 2 +IN –198 –58 Noninverting Input. 3 VREG –196 –346 Regulator Voltage. 4 NC No Connect. 5 OUT +196 –348 Output. 6 GND +196 +447 Ground. 7 NC No Connect. 8 –IN –31 +449 Inverting Input. Rev. A | Page 5 of 16 Document Outline Features Applications Functional Block Diagram General Description Revision History Specifications Absolute Maximum Ratings ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Theory of Operation Comparator Offset and Hysteresis Setting the Input Threshold Voltage Input-Referred Dynamic Error Applications Typical Setup and Calculations High Side Overcurrent Detection Outline Dimensions Ordering Guide Automotive Products
