Datasheet AD8210 (Analog Devices) - 8
DescriptionHigh Voltage, Bidirectional Current Shunt Monitor
Pages / Page15 / 8 — AD8210. Data Sheet. 5.0. 4.9. 4.8. 50V/DIV. 4.7. 4.6. GE N. 4.5. A R. …
RevisionE
File Format / SizePDF / 284 Kb
AD8210. Data Sheet. 5.0. 4.9. 4.8. 50V/DIV. 4.7. 4.6. GE N. 4.5. A R. 4.4. 100mV/DIV. 4.3. 4.2. OLTA. 4.1. T V U. 4.0. 3.9. 3.8. 3.7. 3.6. 3.5
AD8210 Data Sheet 5.0 4.9 4.8 50V/DIV 4.7 4.6 GE N 4.5 A R 4.4 100mV/DIV 4.3 4.2 OLTA 4.1 T V U 4.0 3.9 3.8 3.7 3.6 3.5
AD8210 Data Sheet 5.0 4.9 4.8 ) 50V/DIV V 4.7 ( 4.6 GE N 4.5 A R 4.4 100mV/DIV GE 4.3 4.2 OLTA 4.1 T V U 4.0 TP 3.9 OU 3.8 3.7 3.6
020
3.5 0 0.5 1.0 1.5 2.0 2.5 3.0 3.5 4.0 4.5 5.0 5.5 6.0 6.5
023
1µs/DIV
05147-
OUTPUT SOURCE CURRENT (mA)
05147- Figure 16. Common-Mode Response (Rising) Figure 19. Output Voltage Range vs. Output Source Current
8 1.4 ) V 7 ( mA) D 1.2 ( NT GN 6 OM 1.0 5 FR GE 0.8 INK CURRE N A S 4 R UT 0.6 P GE 3 UT O OLTA 0.4 UM 2 T V IM U AX TP 0.2 1 M OU 0 0 –40 –20 0 20 40 60 80 100 120 140
022
0 1 2 3 4 5 6 7 8 9
038
TEMPERATURE (°C) OUTPUT SINK CURRENT (mA)
05147- 05147- Figure 17. Output Sink Current vs. Temperature Figure 20. Output Voltage Range from GND vs. Output Sink Current
11 6.0 10 5.5 mA) ( NT 9 5.0 8 4.5 mA) CURRE 7 ( NT 4.0 URCE 6 O 3.5 S 5 CURRE UT Y 3.0 P L 4 P UT UP 2.5 O 3 S UM 2.0 2 IM AX 1 1.5 M 0 1.0 –40 –20 0 20 40 60 80 100 120 140
026
–2 0 2 4 6 8 65
027
TEMPERATURE (°C) COMMON-MODE VOLTAGE (V)
05147- 05147- Figure 18. Output Source Current vs. Temperature Figure 21. Supply Current vs. Common-Mode Voltage Rev. E | Page 8 of 15 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION MODES OF OPERATION UNIDIRECTIONAL OPERATION Ground Referenced Output V+ Referenced Output BIDIRECTIONAL OPERATION External Referenced Output Splitting an External Reference Splitting the Supply INPUT FILTERING APPLICATIONS INFORMATION HIGH-SIDE CURRENT SENSE WITH A LOW-SIDE SWITCH HIGH-SIDE CURRENT SENSE WITH A HIGH-SIDE SWITCH H-BRIDGE MOTOR CONTROL OUTLINE DIMENSIONS ORDERING GUIDE AUTOMOTIVE PRODUCTS
