Datasheet AD8206 (Analog Devices) - 8
DescriptionHigh Common-Mode Voltage, Bidirectional Current Shunt Amplifier
Pages / Page13 / 8 — AD8206. Data Sheet. 0.50. 0.45. 0.40. 0.35. 250mV/DIV. 0.30. 0.25. 0.20. …
RevisionC
File Format / SizePDF / 363 Kb
AD8206. Data Sheet. 0.50. 0.45. 0.40. 0.35. 250mV/DIV. 0.30. 0.25. 0.20. 0.15. 0.10. 2V/DIV. MAXIMUM OUTPUT SINK CURRENT (mA) 0.05. –40. –20. 100. 120. 140
AD8206 Data Sheet 0.50 0.45 0.40 0.35 250mV/DIV 0.30 0.25 0.20 0.15 0.10 2V/DIV MAXIMUM OUTPUT SINK CURRENT (mA) 0.05 –40 –20 100 120 140
024 04953-030 04953-
0 –40 –20 0 20 40 60 80 100 120 140 2
s/DIV TEMPERATURE ( C)
Figure 10. Differential Overload Recovery (Rising) Figure 13. Output Sink Current vs. Temperature
10 9 8 7 2V/DIV 6 5 0.01%/DIV 4 3 2 1
022
MAXIMUM OUTPUT SOURCE CURRENT (mA)
04953-031 04953-
0 40
s/DIV –40 –20 0 20 40 60 80 100 120 140 TEMPERATURE ( C)
Figure 11. Settling Time Figure 14. Output Source Current vs. Temperature
5.0 4.9 4.8 50V/DIV 4.7 4.6 4.5 4.4 4.3 50mV/DIV 4.2 4.1 4.0 3.9 3.8 OUTPUT VOLTAGE RANGE (V p-p) 3.7
026
3.6 3.5
04953-034 04953-
0 0.5 1.0 1.5 2.0 2.5 3.0 3.5 4.0 1
s/DIV OUTPUT SOURCE CURRENT (mA)
Figure 12. Common-Mode Response Figure 15. Output Voltage Range vs. Output Source Current Rev. C | Page 8 of 13 Document Outline FEATURES EXCELLENT AC AND DC PERFORMANCE APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION OUTPUT OFFSET ADJUSTMENT UNIDIRECTIONAL OPERATION GROUND REFERENCED OUTPUT V+ REFERENCED OUTPUT BIDIRECTIONAL OPERATION EXTERNAL REFERENCED OUTPUT SPLITTING THE SUPPLY SPLITTING AN EXTERNAL REFERENCE APPLICATIONS INFORMATION HIGH-SIDE CURRENT SENSE WITH A LOW-SIDE SWITCH HIGH-SIDE CURRENT SENSE WITH A HIGH-SIDE SWITCH OUTLINE DIMENSIONS ORDERING GUIDE AUTOMOTIVE PRODUCTS
