Datasheet AD8203 (Analog Devices) - 4
DescriptionHigh Common-Mode Voltage, Single-Supply Difference Amplifier
Pages / Page20 / 4 — AD8203. Data Sheet. ABSOLUTE MAXIMUM RATINGS Table 2. Parameter. Rating. …
RevisionD
File Format / SizePDF / 293 Kb
AD8203. Data Sheet. ABSOLUTE MAXIMUM RATINGS Table 2. Parameter. Rating. ESD CAUTION
AD8203 Data Sheet ABSOLUTE MAXIMUM RATINGS Table 2 Parameter Rating ESD CAUTION
AD8203 Data Sheet ABSOLUTE MAXIMUM RATINGS Table 2. Parameter Rating
Stresses above those listed under Absolute Maximum Ratings Supply Voltage 12.5 V may cause permanent damage to the device. This is a stress Transient Input Voltage (400 ms) 44 V rating only; functional operation of the device at these or any Continuous Input Voltage (Common Mode) 35 V other conditions above those indicated in the operational Reversed Supply Voltage Protection 0.3 V section of this specification is not implied. Exposure to absolute Operating Temperature Range maximum rating conditions for extended periods may affect SOIC −40°C to +125°C device reliability. MSOP −40°C to +125°C Storage Temperature −65°C to +150°C Output Short-Circuit Duration Indefinite Lead Temperature Range (Soldering 10 sec) 300°C
ESD CAUTION
ESD (electrostatic discharge) sensitive device. Electrostatic charges as high as 4000 V readily accumulate on the human body and test equipment and can discharge without detection. Although this product features proprietary ESD protection circuitry, permanent damage may occur on devices subjected to high energy electrostatic discharges. Therefore, proper ESD precautions are recommended to avoid performance degradation or loss of functionality. Rev. D | Page 4 of 20 Document Outline Features Applications Functional Block Diagrams Revision History Specifications Single Supply Absolute Maximum Ratings ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Theory of Operation Applications Current Sensing High Line, High Current Sensing Low Current Sensing Gain Adjustment Gains Less Than 14 Gains Greater Than 14 Gain Trim Internal Signal Overload Considerations Low-Pass Filtering High Line Current Sensing with LPF and Gain Adjustment Driving Charge Redistribution ADCs Outline Dimensions Ordering Guide
