Data SheetAD8203040–6V TO +30V COMMON MODE TEMPERATURE = 25 ° C35–10NO LOAD30–2025–3020HITS–4010k Ω LOAD15–5010OUTPUT MINUS SUPPLY (mV)–605–70 05013-012 0 05013-051 34567891011121308–8162432404856647280SUPPLY VOLTAGE (V)–80–72–64–56–48–40–32–24–16CMRR ( µ V/V) Figure 12. Swing Minus Supply vs. Supply Voltage Figure 15. CMRR Distribution, Temperature = 25°C 7VSUPPLY = 5V TEMPERATURE RANGE =6OUTPUT+25 ° C TO –40 ° C54HITS34INPUT213 05013-013 0 05013-025 CH3 100mV Ω CH4 1.0V Ω M 20 µ s 2.5MS/s 400NS/PT02468–8–6–4–2101214 16182022242628 30A CH3 260mV–30 –28–26 –24–22–20–18–16–14–12–10VOS DRIFT ( µ V/ ° C) Figure 13. Pulse Response Figure 16. Offset Drift Distribution, MSOP, Temperature Range = +25°C to −40°C 10008VSUPPLY = 5V8007TEMPERATURE RANGE = 25 ° C TO 85 ° C600–40 ° C+25 ° C64005200 µ V) (04OSHITSV–2003+85 ° C+125 ° C–4002–6001–800–1000 05013-052 0 05013-026 –10–50510152025303502468–8–6–4–2101214 16182022242628 30COMMON-MODE VOLTAGE (V)–30 –28–26 –24–22–20–18–16–14–12–10VOS DRIFT ( µ V/ ° C) Figure 14. VOS vs. Common-Mode Voltage Figure 17. Offset Drift Distribution, MSOP, Temperature Range = 25°C to 85°C Rev. D | Page 7 of 20 Document Outline Features Applications Functional Block Diagrams Revision History Specifications Single Supply Absolute Maximum Ratings ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Theory of Operation Applications Current Sensing High Line, High Current Sensing Low Current Sensing Gain Adjustment Gains Less Than 14 Gains Greater Than 14 Gain Trim Internal Signal Overload Considerations Low-Pass Filtering High Line Current Sensing with LPF and Gain Adjustment Driving Charge Redistribution ADCs Outline Dimensions Ordering Guide
