Datasheet AD8202 (Analog Devices) - 4
DescriptionHigh Common-Mode Voltage, Single-Supply Difference Amplifier
Pages / Page20 / 4 — AD8202. Data Sheet. ABSOLUTE MAXIMUM RATINGS Table 2. Parameter. Rating. …
RevisionH
File Format / SizePDF / 302 Kb
AD8202. Data Sheet. ABSOLUTE MAXIMUM RATINGS Table 2. Parameter. Rating. ESD CAUTION
AD8202 Data Sheet ABSOLUTE MAXIMUM RATINGS Table 2 Parameter Rating ESD CAUTION
AD8202 Data Sheet ABSOLUTE MAXIMUM RATINGS Table 2. Parameter Rating
Stresses above those listed under Absolute Maximum Ratings Supply Voltage 12.5 V may cause permanent damage to the device. This is a stress Transient Input Voltage (400 ms) 44 V rating only; functional operation of the device at these or any Continuous Input Voltage (Common Mode) 35 V other conditions above those indicated in the operational Reversed Supply Voltage Protection 0.3 V section of this specification is not implied. Exposure to absolute Operating Temperature Range maximum rating conditions for extended periods may affect Die −40°C to +150°C device reliability. SOIC −40°C to +125°C
ESD CAUTION
MSOP −40°C to +125°C Storage Temperature −65°C to +150°C Output Short-Circuit Duration Indefinite Lead Temperature Range (Soldering, 10 sec) 300°C Rev. H | Page 4 of 20 Document Outline Features Applications General Description Functional Block Diagrams Revision History Specifications Single Supply Absolute Maximum Ratings ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Theory of Operation Applications Current Sensing High Line, High Current Sensing Low Current Sensing Gain Adjustment Gains Less than 20 Gains Greater Than 20 Gain Trim Internal Signal Overload Considerations Low-Pass Filtering High Line Current Sensing with LPF and Gain Adjustment Driving Charge Redistribution ADCs Outline Dimensions Ordering Guide Automotive Products
