Datasheet AD8202 (Analog Devices) - 6
DescriptionHigh Common-Mode Voltage, Single-Supply Difference Amplifier
Pages / Page20 / 6 — AD8202. Data Sheet. TYPICAL PERFORMANCE CHARACTERISTICS. –55. –10. –40. …
RevisionH
File Format / SizePDF / 302 Kb
AD8202. Data Sheet. TYPICAL PERFORMANCE CHARACTERISTICS. –55. –10. –40. –15. +25. –20. PSRR (dB). –25. +125. COMMON-MODE VOLTAGE (V). –30. +150. –35
AD8202 Data Sheet TYPICAL PERFORMANCE CHARACTERISTICS –55 –10 –40 –15 +25 –20 PSRR (dB) –25 +125 COMMON-MODE VOLTAGE (V) –30 +150 –35
TA = 25°C, VS = 5 V, VCM = 0 V, RL = 10 kΩ, unless otherwise noted.
90 0 80 –5 70 –55
C –10 60 –40
C 50 –15 +25
C 40 –20 PSRR (dB) 30 –25 +125
C 20 COMMON-MODE VOLTAGE (V) –30 10 +150
C 0
04981-006
–35
04981-009
10 100 1k 10k 100k 3 4 5 6 7 8 9 10 11 12 13 FREQUENCY (Hz) POWER SUPPLY (V)
Figure 6. Power Supply Rejection Ratio vs. Figure 9. Negative Common-Mode Voltage vs. Voltage Supply Frequency Valid for CM Range −8 V to +28 V
30 40 35 25 30 –55
C 20 25 +150
C 15 20 +125
C OUTPUT (dB) 15 10 –40
C 10 COMMON-MODE VOLTAGE (V) 5 +25
C 5 0
04981-007
0
04981-010
100 1k 10k 100k 1M 3 4 5 6 7 8 9 10 11 12 13 FREQUENCY (Hz) POWER SUPPLY (V)
Figure 7. Bandwidth Figure 10. Positive Common-Mode Voltage vs. Voltage Supply
100 5.0 4.5 95 4.0 3.5 90 3.0 85 2.5 CMRR (dB) 2.0 80 OUTPUT SWING (V) 1.5 1.0 75 0.5 70
04981-008
0
04981-011
10 100 1k 10k 100k 10 100 1k 10k FREQUENCY (Hz) LOAD RESISTANCE (
Figure 8. Common-Mode Rejection Ratio vs. Frequency Figure 11. Output Swing vs. Load Resistance Valid for Common-Mode Range −8 V to +28 V Rev. H | Page 6 of 20 Document Outline Features Applications General Description Functional Block Diagrams Revision History Specifications Single Supply Absolute Maximum Ratings ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Theory of Operation Applications Current Sensing High Line, High Current Sensing Low Current Sensing Gain Adjustment Gains Less than 20 Gains Greater Than 20 Gain Trim Internal Signal Overload Considerations Low-Pass Filtering High Line Current Sensing with LPF and Gain Adjustment Driving Charge Redistribution ADCs Outline Dimensions Ordering Guide Automotive Products
