Datasheet AD8202-KGD (Analog Devices) - 4
DescriptionHigh Voltage, Precision Difference Amplifier
Pages / Page8 / 4 — AD8202-KGD. Known Good Die. ABSOLUTE MAXIMUM RATINGS. Table 2. Parameter. …
File Format / SizePDF / 139 Kb
AD8202-KGD. Known Good Die. ABSOLUTE MAXIMUM RATINGS. Table 2. Parameter. Rating. ESD CAUTION
AD8202-KGD Known Good Die ABSOLUTE MAXIMUM RATINGS Table 2 Parameter Rating ESD CAUTION
AD8202-KGD Known Good Die ABSOLUTE MAXIMUM RATINGS Table 2. Parameter Rating
Stresses above those listed under Absolute Maximum Ratings may cause permanent damage to the device. This is a stress Supply Voltage 12.5 V rating only; functional operation of the device at these or any Continuous Input Voltage (Common Mode) 35 V other conditions above those indicated in the operational Reversed Supply Voltage Protection 0.3 V section of this specification is not implied. Exposure to absolute Operating Temperature Range (Die) −40°C to +150°C maximum rating conditions for extended periods may affect Output Short-Circuit Duration Indefinite device reliability. Lead Temperature Range (Soldering, 10 sec) 300°C
ESD CAUTION
Rev. 0 | Page 4 of 8 Document Outline Features Applications Functional Block Diagram General Description Table of Contents Revision History Specifications Absolute Maximum Ratings ESD Caution Pad Configuration and Function Descriptions Outline Dimensions Die Specifications and Assembly Recommendations Ordering Guide Automotive Products
