Datasheet AD8205 (Analog Devices) - 4
DescriptionSingle Supply 42 V System Difference Amplifier
Pages / Page12 / 4 — AD8205. Data Sheet. ABSOLUTE MAXIMUM RATINGS. Table 2. Parameter Rating. …
RevisionD
File Format / SizePDF / 461 Kb
AD8205. Data Sheet. ABSOLUTE MAXIMUM RATINGS. Table 2. Parameter Rating. ESD CAUTION
AD8205 Data Sheet ABSOLUTE MAXIMUM RATINGS Table 2 Parameter Rating ESD CAUTION
Stresses above those listed under Absolute Maximum Ratings
Table 2.
may cause permanent damage to the device. This is a stress
Parameter Rating
rating only and functional operation of the device at these or Supply Voltage 12.5 V any other conditions above those indicated in the operational Continuous Input Voltage −25 V to +75 V section of this specification is not implied. Exposure to absolute Input Transient Survival −30 V to +80 V maximum rating conditions for extended periods may affect Differential Input Survival −25 V to +75 V device reliability. Reverse Supply Voltage 0.3 V Operating Temperature Range Y and W Grade −40°C to +125°C
ESD CAUTION
H Grade −40°C to +150°C Storage Temperature −65 to +150C Output Short-Circuit Duration Indefinite Rev. D | Page 4 of 12 Document Outline Features Excellent AC and DC Performance Applications Functional Block Diagram General Description Revision History Specifications Absolute Maximum Ratings ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Theory of Operation Output Offset Adjustment Unidirectional Operation Ground Referenced Output V+ Referenced Output Bidirectional Operation External Reference Output Splitting the Supply Splitting an External Reference Applications Information High-Side Current Sense with a Low-Side Switch High-Side Current Sense with a High-Side Switch Outline Dimensions Ordering Guide Automotive Products
