Datasheet MMBT4401 (Diodes) - 2
Manufacturer | Diodes |
Description | 40V NPN SMALL SIGNAL TRANSISTOR IN SOT23 |
Pages / Page | 7 / 2 — MMBT4401. Absolute Maximum Ratings. Thermal Characteristics. … |
File Format / Size | PDF / 264 Kb |
MMBT4401. Absolute Maximum Ratings. Thermal Characteristics. Characteristic Symbol. Value. Unit. ESD Ratings. JEDEC. Class
MMBT4401 Absolute Maximum Ratings
(@TA = +25°C unless otherwise specified) Characteristic Symbol Value Unit Collector-Base Voltage VCBO 60 V Collector-Emitter Voltage VCEO 40 V Emitter-Base Voltage VEBO 6.0 V Collector Current IC 600 mA Peak Collector Current ICM 1 A Peak Base Current IBM 200 mA
(Note 6) 310 Power Dissipation PD mW (Note 7) 350 (Note 6) 403 Thermal Resistance, Junction to Ambient RθJA C/W (Note 7) 357 Thermal Resistance, Junction to Leads (Note 8) RθJL 350 C/W Operating and Storage Temperature Range TJ,TSTG -55 to +150 C
ESD Ratings
(Note 9)
Characteristic Symbol Value Unit JEDEC Class
Electrostatic Discharge - Human Body Model ESD HBM 4,000 V 3A Electrostatic Discharge - Machine Model ESD MM 400 V C Notes: 6. For a device mounted on minimum recommended pad layout 1oz copper that is on a single-sided FR4 PCB; device is measured under still air conditions whilst operating in a steady-state. 7. Same as note (6), except the device is mounted on 15 mm x 15mm 1oz copper. 8. Thermal resistance from junction to solder-point (at the end of the leads). 9. Refer to JEDEC specification JESD22-A114 and JESD22-A115. MMBT4401 2 of 7 November 2013 Document Number: DS30039 Rev. 17 - 2
www.diodes.com
© Diodes Incorporated
