Datasheet TL074 (STMicroelectronics) - 5
DescriptionLow-noise JFET quad operational amplifier
Pages / Page18 / 5 — TL074. Electrical characteristics. 3 Electrical. characteristics
TL074 Electrical characteristics 3 Electrical characteristics
TL074 Electrical characteristics 3 Electrical characteristics Table 3. VCC = ±15 V, Tamb = +25 °C (unless otherwise specified) TL074I,AC,AI, BC,BI TL074C Symbol Parameter Unit Min. Typ. Max. Min. Typ. Max.
Input offset voltage (Rs = 50Ω) Tamb = +25°C TL074 3 10 3 10 TL074A 3 6 Vio TL074B 1 3 mV Tmin ≤ Tamb ≤ TmaxTL074 13 13 TL074A 7 TL074B 5 DVio Input offset voltage drift 10 10 µV/°C Input offset current Iio Tamb = +25°C 5 100 5 100 pA Tmin ≤ Tamb ≤ Tmax 4 10 nA Input bias current -note (1) Iib Tamb = +25°C 20 200 30 200 pA Tmin ≤ Tamb ≤ Tmax 20 20 nA Large signal voltage gain RL= 2kΩ, Vo=±10V 50 200 25 200 Avd Tamb = +25°C V/mV 25 15 Tmin ≤ Tamb ≤ Tmax Supply voltage rejection ratio (RS = 50Ω) 80 86 70 86 SVR Tamb = +25°C dB 80 70 Tmin ≤ Tamb ≤ Tmax Supply current, no load 1.4 2.5 1.4 2.5 ICC Tamb = +25°C mA 2.5 2.5 Tmin ≤ Tamb ≤ Tmax ±11 +15 ±11 +15 Vicm Input common mode voltage range V -12 -12 Common mode rejection ratio (RS = 50Ω) CMR Tamb = +25°C 80 86 70 86 dB Tmin ≤ Tamb ≤ Tmax 80 70 Output short-circuit current Ios Tamb = +25°C 10 40 60 10 40 60 mA Tmin ≤ Tamb ≤ Tmax 10 60 10 60 Output voltage swing Tamb = +25°C RL = 2kΩ 10 12 10 12 ±Vopp RL = 10kΩ 12 13.5 12 13.5 V Tmin ≤ Tamb ≤ Tmax RL = 2kΩ 10 10 RL = 10kΩ 12 12 Slew rate SR 8 13 8 13 V/µs Vin = 10V, RL = 2kΩ, CL = 100pF, unity gain DocID2297 Rev 5 5/18 18 Document Outline 1 Schematic diagram Figure 1. Circuit schematic 2 Absolute maximum ratings and operating conditions Table 1. Absolute maximum ratings Table 2. Operating conditions 3 Electrical characteristics Table 3. VCC = ±15 V, Tamb = +25 °C (unless otherwise specified) Figure 2. Maximum peak-to-peak output voltage versus frequency Figure 3. Maximum peak-to-peak output voltage versus frequency Figure 4. Maximum peak-to-peak output voltage versus frequency Figure 5. Maximum peak-to-peak output voltage versus free air temperature Figure 6. Maximum peak-to-peak output voltage versus load resistance Figure 7. Maximum peak-to-peak output voltage versus supply voltage Figure 8. Input bias current versus free air temperature Figure 9. Large signal differential voltage amplification versus free air temperature Figure 10. Large signal differential voltage amplification and phase shift versus frequency Figure 11. Total power dissipation versus free air temperature Figure 12. Supply current per amplifier versus free air temperature Figure 13. Common mode rejection ratio versus free air temperature Figure 14. Voltage follower large signal pulse response Figure 15. Output voltage versus elapsed time Figure 16. Equivalent input noise voltage versus frequency Figure 17. Total harmonic distortion versus frequency 4 Parameter measurement information Figure 18. Voltage follower Figure 19. Gain-of-10 inverting amplifier 5 Typical applications Figure 20. Audio distribution amplifier Figure 21. Positive feeback bandpass filter Figure 22. Output A Figure 23. Output B 6 Package information 6.1 SO14 package information Figure 24. SO14 package mechanical drawing Table 4. SO14 package mechanical data 7 Ordering information Table 5. Order codes 8 Revision history Table 6. Document revision history
