Datasheet ST7LITEUSx (STMicroelectronics) - 4
Description8-bit MCU with single voltage Flash memory, ADC, timers. ST7ULTRALITE (ST7LITEUS2, ST7LITEUS5)
Pages / Page108 / 4 — ST7LITEUSx. 1 INTRODUCTION. Figure 1. General block diagram
File Format / SizePDF / 889 Kb
ST7LITEUSx 1 INTRODUCTION Figure 1 General block diagram
The ST7ULTRALITE is a member of the ST7 mi- software developers, enabling the design of highly crocontroller family. All ST7 devices are based on efficient and compact application code. In addition a common industry-standard 8-bit core, featuring to standard 8-bit data management, all ST7 micro- an enhanced instruction set. controllers feature true bit manipulation, 8x8 un- The ST7ULTRALITE features FLASH memory signed multiplication and indirect addressing with byte-by-byte In-Circuit Programming (ICP) modes. and In-Application Programming (IAP) capability. For easy reference, all parametric data are located Under software control, the ST7ULTRALITE de- in section 12 on page 67. vice can be placed in WAIT, SLOW, or HALT The devices feature an on-chip Debug Module mode, reducing power consumption when the ap- (DM) to support in-circuit debugging (ICD). For a plication is in idle or standby state. description of the DM registers, refer to the ST7 The enhanced instruction set and addressing ICC Protocol Reference Manual. modes of the ST7 offer both power and flexibility to
Internal AWU RC OSC Clock 8-MHz RC OSC External LITE TIMER Clock with WATCHDOG LVD VDD POWER PORT A SUPPLY VSS ADDRESS AND DATA BUS 12-BIT AUTO- PA5:0 PA3 / RESET CONTROL RELOAD TIMER (6 bits) 8-BIT CORE ALU 10-BIT ADC 1K Byte FLASH MEMORY RAM (128 Bytes) 4/108 1
