Datasheet TLS715B0NAV50 (Infineon) - 7
ManufacturerInfineon
DescriptionOPTIREG Linear TLS715B0NAV50. Low dropout li near voltage regulator
Pages / Page22 / 7 — OPTIREG™ Linear TLS715B0NAV50 Low dropout linear voltage regulator …
Revision01_10
File Format / SizePDF / 686 Kb
OPTIREG™ Linear TLS715B0NAV50 Low dropout linear voltage regulator General product characteristics. 3.2. Functional range
OPTIREG™ Linear TLS715B0NAV50 Low dropout linear voltage regulator General product characteristics 3.2 Functional range
link to page 7 link to page 7 link to page 7 link to page 7 link to page 7 link to page 7
OPTIREG™ Linear TLS715B0NAV50 Low dropout linear voltage regulator General product characteristics 3.2 Functional range Table 2 Functional range Parameter Symbol Values Unit Note or Number Test Condition Min. Typ. Max.
Input voltage range for normal VI VQ,nom + Vdr – 40 V – P_4.2.1 operation Extended input voltage range VI,ext 4.0 – 40 V –1) P_4.2.2 Enable voltage range VEN 0 – 40 V – P_4.2.3 Output capacitor’s CQ 1 – – µF –2) P_4.2.4 requirements for stability Output capacitor’s ESR ESR(CQ) – – 5 Ω –3) P_4.2.5 Junction temperature Ti -40 – 150 °C – P_4.2.6 1) When VI,ext.min < VI < VQ,nom + Vdr, then VQ = VI - Vdr. When VI is below VI,ext,min, thenVQ can drop to 0 V. 2) The minimum output capacitance requirement is applicable for a worst case capacitance tolerance of 30%. 3) Relevant ESR value at f = 10 kHz Note: Within the functional range the IC operates as described in the circuit description. The electrical characteristics are specified within the conditions given in the related electrical characteristics table. Datasheet 7 Rev. 1.1 2019-07-31 Document Outline Features Potential applications Product validation Description Table of contents 1 Block diagram 2 Pin configuration 2.1 Pin assignment PG-TSNP-7 2.2 Pin definitions and functions PG-TSNP-7 3 General product characteristics 3.1 Absolute maximum ratings 3.2 Functional range 3.3 Thermal resistance 4 Block description and electrical characteristics 4.1 Voltage regulation 4.2 Typical performance characteristics voltage regulator 4.3 Current consumption 4.4 Typical performance characteristics current consumption 4.5 Enable 4.6 Typical performance characteristics enable 5 Application information 5.1 Application diagram 5.2 Selection of external components 5.2.1 Input pin 5.2.2 Output pin 5.3 Thermal considerations 5.4 Reverse polarity protection 5.5 Further application information 6 Package information 7 Revision history
