Datasheet XC9276 (Torex)
ManufacturerTorex
DescriptionUltra-Low Quiescent Current, Synchronous Step-Down PFM DC/DC Converter with Output voltage selectable function
Pages / Page28 / 1 — XC9276 Series
File Format / SizePDF / 992 Kb
XC9276 Series
Datasheet XC9276 Torex
XC9276
XC9276 Series
ETR05070-001 Ultra-Low Quiescent Current, Synchronous Step-Down PFM DC/DC Converter with Output voltage selectable function ☆Green Operation compatible ■GENERAL DESCRIPTION The XC9276 Series is a 150mA step-down synchronous rectification DC/DC converter which has an output voltage switch- over function with an ultra-low power consumption circuit and a PFM control. The efficiency performance at a light load current is dramatically improved by implementing ultra-low power consumption circuits which has 200nA consumption current, and PFM control method. Additionally two-preset output voltage switchover function is available with using VSEL pin. This function can select an appropriate output voltage based on the MCU behavior mode and contribute a power consumption reduction for a total system. Due to these functions, XC9276 series are suitable for equipment which needs a high efficiency performance at a light load current, and a long-time battery life. XC9276 series are compatible to 2.2uH inductor therefore it can reduce an output ripple voltage which is a negative side of PFM control method, and a PCB board area size. ■ ■FEATURES APPLICATIONS Input Voltage Range : 1.8V ~ 6.0V ● Smart meter Output Voltage Setting : 0.6V ~ 3.6V (0.05V step) ● Low Power RF Output Voltage Accuracy ±20mV (VOUT(T)≦1.0V) ● Sensor Module ±2.0% (VOUT(T)>1.0V) ● Wearable Devices Output Current : 150mA ● Supply Current : 200nA @ VOUT(T)=1.8V (TYP.) Energy Harvest devices Control Method : PFM control ● Back-up power supply circuit Function : Output Voltage selectable function ● Smart card CL Discharge(D Type) ● Devices with 1 Lithium cell UVLO function Protection Functions : Short Protection Input / Output Capacitor : Ceramic Capacitor Compatible Operation Ambient Temperature : -40 ~ +85℃ Package : WLP-6-03 (1.07 x 1.7 x 0.33mm) SOT-26W (2.9 x 2.8 x 1.3mm) USP-8B06 (2.0 x 2.0 x 0.33mm) Environmentally Friendly EU RoHS compliant, Pb Free ■TYPICAL APPLICATION CIRCUIT ■TYPICAL PERFORMANCE CHARACT ER ISTICS VOUT = 1.8V L=GLUHK2R201A(2.2μH), C IN,CL=GRM188R61A106ME69(10μF) 100 XC9276B1410R-G 90 VIN L : 2.2μH 1.8 ~ 6.0V 80 V L IN X VOUT 0.7V/150mA (VSET=”L”) 70 1.8V/150mA (VSET=”H”) CE ) 60 CIN V C OUT L (Ceramic) (Ceramic) (% VSET 50 GND EFFI 40 30 VIN = 2.7V 20 VIN = 3.6V 10 VIN = 4.2V 0 0.001 0.01 0.1 1 10 100 IOUT(mA) 1/28 Document Outline GRM188R61A106ME69 LMK107BBJ106MALT GRM188R61A106ME69 GRM188R60J226MEA0 GRM188R61A226ME15 GRM188R60J476ME15 LMK107BBJ106MALT JMK107BBJ226MA C1608X5R0J226M080AC
