Data Brief SZ1105 (Silanna)
ManufacturerSilanna
DescriptionFlyback PWM Controller with Integrated Active Clamp Circuit
Pages / Page4 / 1 — SZ1105. Flyback PWM Controller with Integrated Active Clamp Circuit. …
File Format / SizePDF / 430 Kb
SZ1105. Flyback PWM Controller with Integrated Active Clamp Circuit. Features. Product Description. Applications
Data Brief SZ1105 Silanna
SZ1105 Flyback PWM Controller with Integrated Active Clamp Circuit Features Product Description
▪ Integrated UHV Active Clamp FET, Active Clamp The SZ1105 is an Active Clamp Flyback (ACF) PWM Driver and Startup Regulator Controller that integrates an adaptive digital PWM ▪ Capable of Over 93% Efficiency controller and the following Ultra High-Voltage (UHV) ▪ Flat Efficiency Across Universal (90 - 265 Vac) components: active clamp FET, active clamp driver and a startup regulator. Input Voltage and Load ▪ Tight Switching Frequency Regulation for The device provides ease-of-design of a simple flyback Improved Input EMI Filter Utilization controller with all the benefits of an ACF design, including ▪ Up to 140 kHz Switching Frequency Operation recycling of the leakage inductance energy of the flyback ▪ transformer and limiting the primary FET drain voltage OptiMode™ Cycle-by-Cycle Adaptive Digital spike during the turn-off events. Employing Silanna’s Control OptiModeTM digital control architecture, the SZ1105 ▪ Quasi-Resonant (QR), Valley Mode Switching adjusts the device’s mode of operation on a cycle-by-cycle (VMS) for low EMI basis to maintain high efficiency, low EMI, fast dynamic ▪ Multi-Mode Operation (Burst Mode, QR, VMS) load regulation and other key power supply parameters in ▪ Self-Tuning Valley Detection response to varying line voltage and load. ▪ OTP, OVP, OCP, OPP and OSCP Protections Furthermore, the switching frequency is confined within a ▪ <50 mW No Load Power Consumption tight frequency band for simplified EMI filtering. In addition, ▪ Up to 65 W Output Power adaptive digital control of the active clamp operation ▪ 16-pin SOIC Package enables near ZVS turn-on of the primary FET and clamps the drain voltage during the turn-off, thus further improving efficiency and reducing EMI.
Applications
Unlike conventional ACF designs, tight tolerances of the ▪ High Power Density USB-PD AC/DC Power clamp capacitor and leakage inductance values are not Supplies required for proper operation of the circuit in high volume ▪ High Efficiency USB-PD Power Adapters production. Moreover, a small 3.3 nF clamp capacitor is sufficient to realize the benefits of ACF operation. The SZ1105 is well suited for high efficiency and high-power
Application Diagram
density USB-PD AC/DC power adapters, providing up to V 65 W output power. BULK Primary The SZ1105 is available in a space saving 16-pin SOIC Primary FET package. V5OUT BOOT_CL SW GATE ISNS Auxiliary V10 CLAMP CLMP_S SZ1105 VAUX_S VBULK_S TEMP V5OUT DGND GND FB
Figure 1: Active Clamp Flyback Controller Figure 2: Device Package Image
Silanna Semiconductor Proprietary and Confidential Page 1 Patents: www.SilannaSemi.com/patents Document 10854 Ver. 3.0
