Datasheet LTC3421 (Analog Devices) - 3
Description3A, 3MHz Micropower Synchronous Boost Converter with Output Disconnect
Pages / Page18 / 3 — ABSOLUTE MAXIMUM RATINGS. PACKAGE/ORDER INFORMATION. (Note 1). ORDER …
File Format / SizePDF / 479 Kb
ABSOLUTE MAXIMUM RATINGS. PACKAGE/ORDER INFORMATION. (Note 1). ORDER INFORMATION. LEAD FREE FINISH. TAPE AND REEL. PART MARKING
ABSOLUTE MAXIMUM RATINGS PACKAGE/ORDER INFORMATION (Note 1) ORDER INFORMATION LEAD FREE FINISH TAPE AND REEL PART MARKING
LTC3421
VIN, VOUT, VOUTS Voltage ... –0.3V to 6V TOP VIEW BURST, SHDN, SS, ENB, SW, V C LBI LBO V IN V OUT V OUT LBO, LBI, SYNC Voltages ... –0.3V to 6V 24 23 22 21 20 19 Operating Temperature Range FB 1 18 VOUTS (Notes 2, 5) ..–40°C to 85°C SHDN 2 17 VOUT Storage Temperature Range .. –65°C to 125°C VREF 3 25 16 SW Lead Temperature (Soldering, 10 sec) ...300°C ENB 4 GND 15 SW RT 5 14 SW SS 6 13 PGND 7 8 9 10 11 12 I LIM SYNC GND BURST PGND PGND UF PACKAGE 24-LEAD (4mm × 4mm) PLASTIC QFN TJMAX = 125°C, θJA = 40°C/W 1 LAYER BOARD θJA = 35°C/W 4 LAYER BOARD, θJC = 2.6°C/W EXPOSED PAD IS GND (PIN 25) MUST BE SOLDERED TO PCB
ORDER INFORMATION LEAD FREE FINISH TAPE AND REEL PART MARKING PACKAGE DESCRIPTION TEMPERATURE RANGE
LTC3421EUF#PBF LTC3421EUF#TRPBF 3421 24-Lead Plastic QFN –40°C to 85°C Contact the factory for parts specified with wider operating temperature ranges. Tape and reel specifications. Some packages are available in 500 unit reels through designated sales channels with #TRMPBF suffix.
denotes the specifications which apply over the full operating junction temperature range, otherwise specifications are at TA = 25°C. VIN = 1.2V, VOUT = 3.3V, RT = 28k, unless otherwise noted. PARAMETER CONDITIONS MIN TYP MAX UNITS
Minimum VIN Start-Up Voltage ILOAD < 1mA 0.88 1 V Minimum VIN Operating Voltage (Note 4) l 0.5 V Output Voltage Adjust Range 2.25 5.25 V l 2.40 5.25 V Feedback Voltage l 1.196 1.220 1.244 V Feedback Input Current VFB = 1.22V 1 50 nA Quiescent Current—Burst Mode Operation VC = 0V, ENB = 0V (Note 3) 12 20 µA VC = 0V, ENB = 2V (Note 3) 23 50 µA Rev. A For more information www.analog.com 3 Document Outline Description Typical Application Absolute Maximum Ratings Electrical Characteristics Typical Performance Characteristics Pin Functions Block Diagram Operation Package Description Typical Application Related Parts Features Applications Typical Application Description Absolute Maximum Ratings Order Information Electrical Characteristics Package/Order Information Electrical Characteristics Typical Performance Characteristics Pin Functions Block Diagram Operation Low Voltage Start-Up Low Noise Fixed Frequency Operation Burst Mode Operation Output Disconnect and Inrush Limiting Applications Information Component Selection Typical Application Package Description Revision History Typical Application Related Parts
