Datasheet TLP3106A (Toshiba) - 3
Manufacturer | Toshiba |
Description | Photocouplers Photorelay |
Pages / Page | 10 / 3 — TLP3106A. 7. Recommended. Operating. Conditions. (Note). Characteristics. … |
File Format / Size | PDF / 322 Kb |
TLP3106A. 7. Recommended. Operating. Conditions. (Note). Characteristics. Symbol. Note. Min. Typ. Max. Unit. Supply. voltage. VDD. . . 24. V. Input. forward
TLP3106A 7. Recommended Operating Conditions (Note) Characteristics Symbol Note Min Typ. Max Unit Supply voltage VDD 24 V Input forward current IF 5 10 25 mA ON-state current(A connection) ION 4.5 A Operating temperature Topr -20 85 Note: The recommended operating conditions are given as a design guide necessary to obtain the intended performance of the device. Each parameter is an independent value. When creating a system design using this device, the electrical characteristics specified in this data sheet should also be considered. 8. Electrical Characteristics (Unless otherwise specified, Ta = 25 ) Characteristics Symbol Note Test Condition Min Typ. Max Unit LED Input forward voltage VF IF = 10 mA 1.50 1.65 1.80 V Input reverse current IR VR = 5 V 10 µA Input capacitance Ct V = 0 V, f = 1 MHz 70 pF Detector OFF-state current IOFF VOFF = 30 V 1 µA Detector Output capacitance COFF V = 0 V, f = 1 MHz 1200 pF 9. Coupled Electrical Characteristics (Unless otherwise specified, Ta = 25 ) Characteristics Symbol Note Test Condition Min Typ. Max Unit Trigger LED current IFT ION = 1 A 0.3 3 mA Return LED current IFC IOFF = 10µA 0.1 0.3 ON-state resistance(A connection) RON (Note 1) IF = 5 mA, ION = 4.5 A, t < 1 s 22 30 mΩ ON-state resistance(B connection) 11 15 ON-state resistance(C connection) IF = 5 mA, ION = 9 A, t < 1 s 6 8 Note 1: For an application circuit example, see Chapter 12.2. 10. Isolation Characteristics (Unless otherwise specified, Ta = 25 ) Characteristics Symbol Note Test Condition Min Typ. Max Unit Total capacitance (input to output) CS (Note 1) VS = 0 V, f = 1 MHz 0.8 pF Isolation resistance RS (Note 1) VS = 500 V, R.H. ≤ 60% 5 × 1010 1014 Ω Isolation voltage BVS (Note 1) AC, 60 s 1500 Vrms Note 1: This device is considered as a two-terminal device: Pins 1, 2 and 3 are shorted together, and pins 4, 5 and 6 are shorted together. ©2019 3 2019-12-26 Toshiba Electronic Devices & Storage Corporation Rev.2.0
