Datasheet ADAU1328 (Analog Devices)
Description2 ADC/8 DAC with PLL, 192 kHz, 24-Bit Codec
Pages / Page32 / 1 — 2 ADC/8 DAC with PLL,. 192 kHz, 24-Bit Codec. Data Sheet. ADAU1328. …
RevisionB
File Format / SizePDF / 431 Kb
2 ADC/8 DAC with PLL,. 192 kHz, 24-Bit Codec. Data Sheet. ADAU1328. FEATURES. GENERAL DESCRIPTION
Datasheet ADAU1328 Analog Devices, Revision: B
2 ADC/8 DAC with PLL, 192 kHz, 24-Bit Codec Data Sheet ADAU1328 FEATURES GENERAL DESCRIPTION PLL generated or direct master clock
The ADAU1328 is a high performance, single-chip codec that
Low EMI design
provides two analog-to-digital converters (ADCs) with differential
108 dB DAC/107 dB ADC dynamic range and SNR
input and eight digital-to-analog converters (DACs) with
−94 dB THD + N
single-ended output using the Analog Devices, Inc. patented
Single 3.3 V supply
multibit sigma-delta (Σ-Δ) architecture. An SPI port is included,
Tolerance for 5 V logic inputs
allowing a microcontrol er to adjust volume and many other
Supports 24 bits and 8 kHz to 192 kHz sample rates
parameters. The ADAU1328 operates from 3.3 V digital and
Differential ADC input
analog supplies. The ADAU1328 is available in a 48-lead
Single-ended DAC output
(single-ended output) LQFP. Other members of this family
Log volume control with autoramp function
include a differential DAC output version.
SPI® controllable for flexibility Software controllable clickless mute
The ADAU1328 is designed for low EMI. This consideration is
Software power-down
apparent in both the system and circuit design architectures.
Right justified, left justified, I2S and TDM modes
By using the on-board PLL to derive the master clock from the
Master and slave modes up to 16-channel in/out
LR clock or from an external crystal, the ADAU1328 eliminates
48-lead LQFP
the need for a separate high frequency master clock and can also be used with a suppressed bit clock. The digital-to-analog
and analog-to-digital converters are designed using the latest ADI continuous time architectures to further minimize EMI. By
Home theater systems
using 3.3 V supplies, power consumption is minimized, further
Set-top boxes
reducing emissions.
Digital audio effects processors FUNCTIONAL BLOCK DIAGRAM DIGITAL AUDIO INPUT/OUTPUT ADAU1328 SERIAL DATA PORT DAC DAC SDATA SDATA DAC OUT IN DIGITAL ADC CLOCKS FILTER DAC DEC AND FILTER VOLUME 48/96/ DAC ADC CONTROL 192kHz TIMING MANAGEMENT AND CONTROL DAC (CLOCK AND PLL) DAC DAC CONTROL PRECISION PORT VOLTAGE SPI REFERENCE 12.488MHz 6.144MHz CONTROL DATA
001
INPUT/OUTPUT
06102- Figure 1.
Rev. B Document Feedback Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rights of third parties that may result from its use. Specifications subject to change without notice. No One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Tel: 781.329.4700 ©2006-2013 Analog Devices, Inc. All rights reserved. Trademarks and registered trademarks are the property of their respective owners. Technical Support www.analog.com
Document Outline Features Applications General Description Functional Block Diagram Table of Contents Revision History Specifications Test Conditions Analog Performance Specifications Crystal Oscillator Specifications Digital Input/Output Specifications Power Supply Specifications Digital Filters Timing Specifications Absolute Maximum Ratings Thermal Resistance ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Theory of Operation Analog-to-Digital Converters (ADCs) Digital-to-Analog Converters (DACs) Clock Signals Reset and Power-Down Serial Control Port Power Supply and Voltage Reference Serial Data Ports—Data Format Time-Division Multiplexed (TDM) Modes Daisy-Chain Mode Control Registers Definitions PLL and Clock Control Registers DAC Control Registers ADC Control Registers Additional Modes Application Circuits Outline Dimensions Ordering Guide
