Datasheet PI6CG33201C (Diodes) - 5
ManufacturerDiodes
Description3.3V Very Low Power 2-Output PCIe Clock Generator With On-chip Termination
Pages / Page24 / 5 — PI6CG33201C. Maximum Ratings. Note:. Operating Conditions. Symbol. …
PI6CG33201C. Maximum Ratings. Note:. Operating Conditions. Symbol. Parameters. Conditions. Min. Typ. Max. Units
PI6CG33201C Maximum Ratings Note: Operating Conditions Symbol Parameters Conditions Min Typ Max Units
A product Line of Diodes Incorporated
(Above which useful life may be impaired. For user guidelines, not tested.) Storage Temperature .. –65°C to +150°C
Note:
Stresses greater than those listed under MAXI- Supply Voltage to Ground Potential, VDDxx ..–0.5V to +4.6V MUM RATINGS may cause permanent damage to the device. This is a stress rating only and functional Input Voltage ... –0.5V to VDD+0.5V, not exceed 4.6V operation of the device at these or any other conditions SMBus, Input High Voltage .. 3.6V above those indicated in the operational sections of ESD Protection (HBM) ... 2000 V this specification is not implied. Exposure to absolute Max Junction Temperature ..+125ºC maximum rating conditions for extended periods may affect reliability.
Temperature = TA; Supply voltages per normal operation conditions; See test circuits for the load conditions
Symbol Parameters Conditions Min. Typ. Max. Units
VDD, VDDA, VDD_OSC, Power Supply Voltage 3.135 3.3 3.465 V VDD_DIG, IDDA Analog Power Supply Current All outputs active @100MHz 22 25 mA IDD Power Supply Current(3) All VDD, except VDDA, All outputs active @100MHz 24 30 mA I Analog Power Supply Wake-on- DDA_WL LAN(1) Current Q outputs off, REF output running 0.5 1.0 mA I Power Supply Wake-on-LAN(1) All VDD, except VDDA, Q outputs DD_WL Current off, REF output running 3.0 6.0 mA I Analog Power Supply Power DDA_PD Down(2) Current All outputs off 0.5 1.0 mA I Power Supply Power Down(2) DD_PD Current All outputs off 1.0 2.0 mA TA Ambient Temperature Industrial grade –40 85 °C
Note:
1. Wake-on-LAN mode: PD# = '0' Byte 3, bit 5 = '1' 2. Power down mode: PD# = '0' Byte 3, bit 5 = '0' 3. Outputs drive 5 inch trace. PI6CG33201C www.diodes.com January 2020 Document Number DS42291 Rev 3-2 5 Diodes Incorporated
