Datasheet PI6CB33801 (Diodes) - 3
Manufacturer | Diodes |
Description | Very-Low-Power 8-Output PCIe Clock Buffer with On-Chip Termination |
Pages / Page | 21 / 3 — PI6CB33801. Pin Description Cont. Pin Number Pin Name. Type. Description |
File Format / Size | PDF / 1.2 Mb |
A product Line of Diodes Incorporated
PI6CB33801 Pin Description Cont. Pin Number Pin Name Type Description
16 Q0- Output HCSL Differential complementary clock output 17 OE1# Input CMOS Active low input for enabling Q1 pair. This pin has an internal pull- down. 1 =disable outputs, 0 = enable outputs 18 Q1+ Output HCSL Differential true clock output 19 Q1- Output HCSL Differential complementary clock output 20, 38 VDD Power — Power supply, nominal 3.3V 22, 40 GND Power — Ground 23 Q2+ Output HCSL Differential true clock output 24 Q2- Output HCSL Differential complementary clock output 25 OE2# Input CMOS Active low input for enabling Q2 pair. This pin has an internal pull- down. 1 =disable outputs, 0 = enable outputs 26 Q3+ Output HCSL Differential true clock output 27 Q3- Output HCSL Differential complementary clock output 28 OE3# Input CMOS Active low input for enabling Q3 pair. This pin has an internal pull- down. 1 =disable outputs, 0 = enable outputs 29 GNDA Power — Ground for analog circuitry 30 VDDA Power — Power supply for analog circuitry 32 Q4+ Output HCSL Differential true clock output 33 Q4- Output HCSL Differential complementary clock output 34 OE4# Input CMOS Active low input for enabling Q4 pair. This pin has an internal pull- down. 1 =disable outputs, 0 = enable outputs 35 Q5+ Output HCSL Differential true clock output 36 Q5- Output HCSL Differential complementary clock output 37 OE5# Input CMOS Active low input for enabling Q5 pair. This pin has an internal pull- down. 1 =disable outputs, 0 = enable outputs 41 Q6+ Output HCSL Differential true clock output 42 Q6- Output HCSL Differential complementary clock output 43 OE6# Input CMOS Active low input for enabling Q6 pair. This pin has an internal pull- down. 1 =disable outputs, 0 = enable outputs 44 Q7+ Output HCSL Differential true clock output 45 Q7- Output HCSL Differential complementary clock output 46 OE7# Input CMOS Active low input for enabling Q7 pair. This pin has an internal pull- down. 1 =disable outputs, 0 = enable outputs Input notifies device to sample latched inputs and start up on first high 48 PD# Input CMOS assertion. Low enters Power Down Mode; subsequent high assertions exit Power Down Mode. This pin has internal pull-up resistor. 49 EPAD Power — Connect to ground PI6CB33801 www.diodes.com January 2020 Document Number DS41288 Rev 5-2 3 Diodes Incorporated
