VOMA618A www.vishay.com Vishay Semiconductors ELECTRICAL CHARACTERISTICS (Tamb = 25 °C, unless otherwise specified) PARAMETERTEST CONDITIONSYMBOLMIN.TYP.MAX.UNITINPUT Forward voltage IF = 1 mA VF - 1.28 1.4 V Reverse current VR = 5 V IR - - 10 μA Capacitance VR = 0 V, f = 1 MHz CI - 40 - pF OUTPUT Collector emitter leakage current VCE = 50 V ICEO - 1 100 nA Collector emitter breakdown voltage IC = 100 μA BVCEO 80 - - V Collector emitter capacitance VCE = 5 V, f = 1 MHz CCE - 7 - pF COUPLER Collector emitter saturation voltage IF = 1 mA, IC = 0.25 mA VCEsat - 0.12 0.4 V Cut-off frequency IF = 10 mA, VCC = 5 V, RL = 100 Ω fCTR - 155 - kHz Coupling capacitance f = 1 MHz CIO - 1.2 - pF Note • Minimum and maximum values are testing requirements. Typical values are characteristics of the device and are the result of engineering evaluation. Typical values are for information only and are not part of the testing requirements CURRENT TRANSFER RATIO (Tamb = 25 °C, unless otherwise specified) PARAMETERTEST CONDITIONPARTSYMBOLMIN.TYP.MAX.UNIT VOMA618A CTR 50 - 600 % VOMA618A-2 CTR 63 - 125 % IC/IF IF = 1 mA, VCE = 5 V VOMA618A-3 CTR 100 - 200 % VOMA618A-4 CTR 160 - 320 % VOMA618A-8 CTR 130 - 260 % SWITCHING CHARACTERISTICS (Tamb = 25 °C, unless otherwise specified) PARAMETERTEST CONDITIONSYMBOLMIN.TYP.MAX.UNITNON-SATURATED Rise time tr - 1.8 - μs Fall time I t C = 2 mA, VCC = 5 V, f - 1.7 - μs R Turn-on time L = 100 Ω ton - 6.8 - μs Turn-off time toff - 2.3 - μs SATURATED Rise time tr - 5.4 - μs Fall time I t F = 1 mA, VCC = 5 V, f - 5.8 - μs R Turn-on time L = 1.9 kΩ ton - 10.0 - μs Turn-off time toff - 6.6 - μs V = 5 V CC Input pulse Input RL V 5 V OUT 90 % Output pulse 10 % min. tr tf t t on off 23029 22986 Fig. 3 - Test Circuit for Switching Characteristics Fig. 4 - Parameter and Limit Definition Rev. 1.1, 05-Jul-2019 3 Document Number: 84949 For technical questions, contact: optocoupleranswers@vishay.com THIS DOCUMENT IS SUBJECT TO CHANGE WITHOUT NOTICE. THE PRODUCTS DESCRIBED HEREIN AND THIS DOCUMENT ARE SUBJECT TO SPECIFIC DISCLAIMERS, SET FORTH AT www.vishay.com/doc?91000
