Datasheet ACS37612 (Allegro) - 2
ManufacturerAllegro
DescriptionCoreless, High Precision, Hall-Effect Current Sensor IC with Common-Mode Field Rejection and High Bandwidth (240 kHz)
Pages / Page22 / 2 — Coreless, High Precision, Hall-Effect Current Sensor IC. ACS37612
File Format / SizePDF / 2.3 Mb
Coreless, High Precision, Hall-Effect Current Sensor IC ACS37612
Coreless, High Precision, Hall-Effect Current Sensor IC ACS37612 with Common-Mode Field Rejection and High Bandwidth (240 kHz) SELECTION GUIDE Differential Sensitivity Part Number Magnetic Sens (Typ.) Nominal Supply Bandwidth TA Input Range, (G) (mV/G) [1] Voltage (V) (kHz) (°C) Packing [2]
ACS37612LLUATR-005B5 ±400 5 5 ACS37612LLUATR-010B3 ±135 10 3.3 ACS37612LLUATR-010B5 ±200 10 5 140 –40 to 150 4000 pieces per 13-inch reel ACS37612LLUATR-015B5 ±130 15 5 ACS37612LLUATR-015U5 0 to 265 15 5 [1] Measured at nominal supply voltage. Contact Allegro for other sensitivity options. [2] Contact Allegro for additional packing options. ACS 37612 L LUA TR - 010 B 3 Clamps: [blank] – Default, Clamps disabled C – Clamps enabled Bandwidth: [blank] – Default, BW = 140 kHz H – High, BW = 240 kHz Supply Voltage: 5 – VCC = 5 V 3 – VCC = 3.3 V Output Directionality: B – Bidirectional (positive and negative current) U – Unidirectional (only positive current) Typical Sensitivity (mV/G) Packing Designator Package Designator Operating Temperature Range 5-Digit Part Number Allegro Current Sensor 2 Allegro MicroSystems 955 Perimeter Road Manchester, NH 03103-3353 U.S.A. www.allegromicro.com
