Datasheet ADT7420 (Analog Devices) - 9
Description±0.25°C Accurate, 16-Bit Digital I2C Temperature Sensor
Pages / Page24 / 9 — Data Sheet. ADT7420. 140. 125°C. 120. 105°C. 100. (°C). 85°C. URE T. A R. …
RevisionA
File Format / SizePDF / 445 Kb
Data Sheet. ADT7420. 140. 125°C. 120. 105°C. 100. (°C). 85°C. URE T. A R. IT TAKES LESS THAN. 2 SECONDS TO REACH 63.2%. OF ITS TEMPERATURE SPAN
Data Sheet ADT7420 140 125°C 120 105°C 100 (°C) 85°C URE T A R IT TAKES LESS THAN 2 SECONDS TO REACH 63.2% OF ITS TEMPERATURE SPAN
Data Sheet ADT7420 140 125°C 120 105°C 100 (°C) 85°C URE T 80 A R IT TAKES LESS THAN E 2 SECONDS TO REACH 63.2% P 60 M OF ITS TEMPERATURE SPAN E T 40 DUT 20 0 0 5 10 15 20 25
10 1 3-
TIME (s)
901 0 Figure 10. Thermal Response Time Rev. A | Page 9 of 24 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION PRODUCT HIGHLIGHTS FUNCTIONAL BLOCK DIAGRAM TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS I2C TIMING SPECIFICATIONS Timing Diagram ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION CIRCUIT INFORMATION CONVERTER DETAILS NORMAL MODE ONE-SHOT MODE CT and INT Operation in One-Shot Mode 1 SPS MODE SHUTDOWN FAULT QUEUE TEMPERATURE DATA FORMAT TEMPERATURE CONVERSION FORMULAS 16-Bit Temperature Data Format 13-Bit Temperature Data Format 10-Bit Temperature Data Format 9-Bit Temperature Data Format REGISTERS ADDRESS POINTER REGISTER TEMPERATURE VALUE REGISTERS STATUS REGISTER CONFIGURATION REGISTER THIGH SETPOINT REGISTERS TLOW SETPOINT REGISTERS TCRIT SETPOINT REGISTERS THYST SETPOINT REGISTER ID REGISTER SERIAL INTERFACE SERIAL BUS ADDRESS WRITING DATA READING DATA RESET GENERAL CALL INT AND CT OUTPUTS UNDERTEMPERATURE AND OVERTEMPERATURE DETECTION Comparator Mode Interrupt Mode APPLICATIONS INFORMATION THERMAL RESPONSE TIME SUPPLY DECOUPLING POWERING FROM A SWITCHING REGULATOR TEMPERATURE MEASUREMENT QUICK GUIDE TO MEASURING TEMPERATURE OUTLINE DIMENSIONS ORDERING GUIDE
