Datasheet ADT7311 (Analog Devices) - 21
DescriptionAutomotive, ±0.5°C Accurate, 16-Bit Digital SPI Temperature Sensor
Pages / Page24 / 21 — Data Sheet. ADT7311. TEMPERATURE. –13°C. –14°C. –15°C. TLOW + THYST. …
File Format / SizePDF / 381 Kb
Data Sheet. ADT7311. TEMPERATURE. –13°C. –14°C. –15°C. TLOW + THYST. –16°C. –17°C. –18°C. –19°C. –20°C. TLOW. –21°C. –22°C. INT PIN. (COMPARATOR MODE)
Data Sheet ADT7311 TEMPERATURE –13°C –14°C –15°C TLOW + THYST –16°C –17°C –18°C –19°C –20°C TLOW –21°C –22°C INT PIN (COMPARATOR MODE)
Data Sheet ADT7311 TEMPERATURE –13°C –14°C –15°C TLOW + THYST –16°C –17°C –18°C –19°C –20°C TLOW –21°C –22°C INT PIN (COMPARATOR MODE) POLARITY = ACTIVE LOW INT PIN (INTERRUPT MODE) POLARITY = ACTIVE LOW INT PIN (COMPARATOR MODE) POLARITY = ACTIVE HIGH INT PIN (INTERRUPT MODE) POLARITY = ACTIVE HIGH TIME
21 0 0-
READ READ READ
05 09 Figure 20. INT Output Temperature Response Diagram for TLOW Undertemperature Events Rev. 0 | Page 21 of 24 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION PRODUCT HIGHLIGHTS FUNCTIONAL BLOCK DIAGRAM TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS SPI TIMING SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION CIRCUIT INFORMATION CONVERTER DETAILS TEMPERATURE MEASUREMENT ONE-SHOT MODE 1 SPS MODE CT and INT Operation in One-Shot Mode SHUTDOWN FAULT QUEUE TEMPERATURE DATA FORMAT TEMPERATURE CONVERSION FORMULAS 16-Bit Temperature Data Format 13-Bit Temperature Data Format 10-Bit Temperature Data Format 9-Bit Temperature Data Format REGISTERS STATUS REGISTER CONFIGURATION REGISTER TEMPERATURE VALUE REGISTER ID REGISTER TCRIT SETPOINT REGISTER THYST SETPOINT REGISTER THIGH SETPOINT REGISTER TLOW SETPOINT REGISTER SERIAL PERIPHERAL INTERFACE SPI COMMAND BYTE WRITING DATA READING DATA INTERFACING TO DSPs OR MICROCONTROLLERS SERIAL INTERFACE RESET INT AND CT OUTPUTS UNDERTEMPERATURE AND OVERTEMPERATURE DETECTION Comparator Mode Interrupt Mode APPLICATIONS INFORMATION THERMAL RESPONSE TIME SUPPLY DECOUPLING POWERING FROM A SWITCHING REGULATOR TEMPERATURE MONITORING QUICK GUIDE TO MEASURING TEMPERATURE OUTLINE DIMENSIONS ORDERING GUIDE AUTOMOTIVE PRODUCTS
