Datasheet ADT7410 (Analog Devices) - 8
Description±0.5°C Accurate, 16-Bit Digital I2C Temperature Sensor
Pages / Page24 / 8 — ADT7410. Data Sheet. 0.30. 160. 140. 0.25. DD CONTINUOUS CONVERSION. 120. …
RevisionC
File Format / SizePDF / 437 Kb
ADT7410. Data Sheet. 0.30. 160. 140. 0.25. DD CONTINUOUS CONVERSION. 120. 0.20. 100. E (° R U. mA) 0.15. I DD. 0.10. EMPER T. IDD 1SPS. 0.05. 2.5. 3.0. 3.5
ADT7410 Data Sheet 0.30 160 140 0.25 DD CONTINUOUS CONVERSION 120 0.20 100 E (° R U mA) 0.15 I DD 0.10 EMPER T IDD 1SPS 0.05 2.5 3.0 3.5
ADT7410 Data Sheet 0.30 160 I 140 0.25 DD CONTINUOUS CONVERSION 120 ) 0.20 C 100 E (° R U mA) 0.15 T ( 80 A I DD 60 0.10 EMPER T 40 IDD 1SPS 0.05 20 0 0 2.5 3.0 3.5 4.0 4.5 5.0 5.5 6.0
008
0 5 10 15 20 25 30 35 40
011
SUPPLY VOLTAGE (V) TIME (Seconds)
06560- 06560- Figure 9. Average Operating Supply Current vs. Supply Voltage at 25°C Figure 11. Response to Thermal Shock
8 7 6 A) µ ( 5 DD N I 4 W DO 3 HUT S 2 1 0 2.5 3.0 3.5 4.0 4.5 5.0 5.5 6.0
009
SUPPLY VOLTAGE (V)
06560- Figure 10. Shutdown Current vs. Supply Voltage at 25°C Rev. C | Page 8 of 24 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS I2C TIMING SPECIFICATIONS Timing Diagram ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION CIRCUIT INFORMATION CONVERTER DETAILS TEMPERATURE MEASUREMENT ONE-SHOT MODE 1 SPS MODE CT and INT Operation in One-Shot Mode SHUTDOWN FAULT QUEUE TEMPERATURE DATA FORMAT TEMPERATURE CONVERSION FORMULAS 16-Bit Temperature Data Format 13-Bit Temperature Data Format 10-Bit Temperature Data Format 9-Bit Temperature Data Format REGISTERS ADDRESS POINTER REGISTER TEMPERATURE VALUE REGISTERS STATUS REGISTER CONFIGURATION REGISTER THIGH SETPOINT REGISTERS TLOW SETPOINT REGISTERS TCRIT SETPOINT REGISTERS THYST SETPOINT REGISTER ID REGISTER SERIAL INTERFACE SERIAL BUS ADDRESS WRITING DATA READING DATA RESET GENERAL CALL INT AND CT OUTPUTS UNDERTEMPERATURE AND OVERTEMPERATURE DETECTION Comparator Mode Interrupt Mode APPLICATIONS INFORMATION THERMAL RESPONSE TIME SUPPLY DECOUPLING TEMPERATURE MONITORING OUTLINE DIMENSIONS ORDERING GUIDE
