Datasheet ADT7411 (Analog Devices) - 7
DescriptionSPI-/I2C-Compatible, 10-Bit Digital Temperature Sensor and 8-Channel ADC
Pages / Page36 / 7 — Data Sheet. ADT7411. ABSOLUTE MAXIMUM RATINGS Table 2. Table 3. I2C …
RevisionC
File Format / SizePDF / 843 Kb
Data Sheet. ADT7411. ABSOLUTE MAXIMUM RATINGS Table 2. Table 3. I2C Address Selection. Parameter Rating. ADD Pin. I2C Address
Data Sheet ADT7411 ABSOLUTE MAXIMUM RATINGS Table 2 Table 3 I2C Address Selection Parameter Rating ADD Pin I2C Address
Data Sheet ADT7411 ABSOLUTE MAXIMUM RATINGS Table 2. Table 3. I2C Address Selection Parameter Rating ADD Pin I2C Address
VDD to GND −0.3 V to +7 V Low 1001 000 Analog Input Voltage to GND −0.3 V to VDD + 0.3 V Float 1001 010 Digital Input Voltage to GND −0.3 V to VDD + 0.3 V High 1001 011 Operating Temperature Range −40°C to +120°C Stresses at or above those listed under Absolute Maximum Storage Temperature Range −65°C to +150°C Ratings may cause permanent damage to the product. This is a Junction Temperature stress rating only; functional operation of the product at these 16-Lead QSOP 150°C or any other conditions above those indicated in the operational Power Dissipation1 (TJmax − TA)/θJA section of this specification is not implied. Operation beyond Thermal Impedance2 the maximum operating conditions for extended periods may θJA Junction-to-Ambient 105.44°C/W affect product reliability. θJC Junction-to-Case 38.8°C/W IR Reflow Soldering
ESD CAUTION
Peak Temperature 220°C (0°C/5°C) Time at Peak Temperature 10 sec to 20 sec Ramp-Up Rate 2°C/sec to 3°C/sec Ramp-Down Rate −6°C/sec IR Reflow Soldering (Pb-Free Package) Peak Temperature 260°C (+0°C) Time at Peak Temperature 20 sec to 40 sec Ramp-Up Rate 3°C/sec maximum Ramp-Down Rate −6°C/sec maximum Time 25°C to Peak Temperature 8 minutes maximum 1 Values relate to package being used on a 4-layer board. 2 Junction-to-case resistance is applicable to components featuring a preferential flow direction, for example, components mounted on a heat sink. Junction-to-ambient resistance is more useful for air-cooled PCB- mounted components. Rev. C | Page 7 of 36 Document Outline Features Applications Pin Configuration General Description Revision History Specifications Functional Block Diagram Absolute Maximum Ratings ESD Caution Pin Configuration and Functional Descriptions Terminology Typical Performance Characteristics Theory of Operation Power-Up Calibration Conversion Speed Functional Description Analog Inputs Single-Ended Inputs Converter Operation ADC Transfer Function Analog Input ESD Protection AIN Interrupts Functional Description—Measurement Temperature Sensor VDD Monitoring On-Chip Reference Round Robin Measurement Single-Channel Measurement Temperature Measurement Method Internal Temperature Measurement External Temperature Measurement Layout Considerations Temperature Value Format Interrupts ADT7411 Registers Interrupt Status 1 Register (Read-Only) [Address = 00h] Interrupt Status 2 Register (Read-Only) [Address = 01h] Internal Temperature Value/VDD Value Register LSBs (Read-Only) [Address = 03h] External Temperature Value and AIN1 to AIN4 Register LSBs (Read-Only) [Address = 04h] AIN5 to AIN8 Registers LSBs (Read-Only) [Address = 05h] VDD Value Register MSBs (Read-Only) [Address = 06h] Internal Temperature Value Register MSBs (Read-Only) [Address = 07h] External Temperature Value or AIN1 Register MSBs (Read-Only) [Address = 08h] AIN2 Register MSBs (Read) [Address = 09h] AIN3 Register MSBs (Read) [Address = 0Ah] AIN4 Register MSBs (Read) [Address = 0Bh] AIN5 Register MSBs (Read) [Address = 0Ch] AIN6 Register MSBs (Read) [Address = 0Dh] AIN7 Register MSBs (Read) [Address = 0Eh] AIN8 Register MSBs (Read) [Address = 0Fh] Control Configuration 1 Register (Read/Write) [Address = 18h] Control Configuration 2 Register (Read/Write) [Address = 19h] Control Configuration 3 Register (Read/Write) [Address = 1Ah] Interrupt Mask 1 Register (Read/Write) [Address = 1Dh] Interrupt Mask 2 Register (Read/Write) [Address = 1Eh] Internal Temperature Offset Register (Read/Write) [Address = 1Fh] External Temperature Offset Register (Read/Write) [Address = 20h] VDD VHIGH Limit Register (Read/Write) [Address = 23h] VDD VLOW Limit Register (Read/Write) [Address = 24h] Internal THIGH Limit Register (Read/Write) [Address = 25h] Internal TLOW Limit Register (Read/Write) [Address = 26h] External THIGH/AIN1 VHIGH Limit Register (Read/Write) [Address = 27h] External TLOW/AIN1 VLOW Limit Register (Read/Write) [Address = 28h] AIN2 VHIGH Limit Register (Read/Write) [Address = 2Bh] AIN2 VLOW Limit Register (Read/Write) [Address = 2Ch] AIN3 VHIGH Limit Register (Read/Write) [Address = 2Dh] AIN3 VLOW Limit Register (Read/Write) [Address = 2Eh] AIN4 VHIGH Limit Register (Read/Write) [Address = 2Fh] AIN4 VLOW Limit Register (Read/Write) [Address = 30h] AIN5 VHIGH Limit Register (Read/Write) [Address = 31h] AIN5 VLOW Limit Register (Read/Write) [Address = 32h] AIN6 VHIGH Limit Register (Read/Write) [Address = 33h] AIN6 VLOW Limit Register (Read/Write) [Address = 34h] AIN7 VHIGH Limit Register (Read/Write) [Address = 35h] AIN7 VLOW Limit Register (Read/Write) [Address = 36h] AIN8 VHIGH Limit Register (Read/Write) [Address = 37h] AIN8 VLOW Limit Register (Read/Write) [Address = 38h] Device ID Register (Read-Only) [Address = 4Dh] Manufacturer’s ID Register (Read-Only) [Address = 4Eh] Silicon Revision Register (Read-Only) [Address = 4Fh] SPI Lock Status Register (Read-Only) [Address = 7Fh] Serial Interface Serial Interface Selection I2C Serial Interface Writing to the ADT7411 Writing to the Address Pointer Register for a Subsequent Read Writing Data to a Register Reading Data from the ADT7411 SPI Serial Interface Write Operation Read Operation SMBus/SPI INT/INTB SMBus Alert Response Outline Dimensions Ordering Guide
