Datasheet AD7314 (Analog Devices)
Description | Low Voltage, 10-Bit Digital Temperature Sensor in 8-Lead MSOP |
Pages / Page | 8 / 1 — Low Voltage, 10-Bit Digital Temperature. Sensor in 8-Lead MSOP. AD7314. … |
Revision | A |
File Format / Size | PDF / 174 Kb |
Low Voltage, 10-Bit Digital Temperature. Sensor in 8-Lead MSOP. AD7314. FEATURES. FUNCTIONAL BLOCK DIAGRAM
a
Low Voltage, 10-Bit Digital Temperature Sensor in 8-Lead MSOP AD7314 FEATURES FUNCTIONAL BLOCK DIAGRAM 10-Bit Temperature-to-Digital Converter –35 C to +85 C Operating Temperature Range BAND GAP 10-BIT 2 C Accuracy TEMPERATURE ANALOG-TO-DIGITAL SPI® and DSP Compatible Serial Interface SENSOR CONVERTER ID Shutdown Mode Space-Saving MSOP Package GND V TEMPERATURE DD VALUE APPLICATIONS AD7314 REGISTER Hard Disk Drives Personal Computers CE SERIAL Electronic Test Equipment SCLK BUS Office Equipment INTERFACE SDI SDO Domestic Appliances Process Control Mobile Phones GENERAL DESCRIPTION PRODUCT HIGHLIGHTS
The AD7314 is a complete temperature monitoring system in 1. The AD7314 has an on-chip temperature sensor that allows an 8-lead MSOP package. It contains a band gap temperature an accurate measurement of the ambient temperature. The sensor and 10-bit ADC to monitor and digitize the temperature measurable temperature range is –35∞C to +85∞C, with a reading to a resolution of 0.25∞C. ±2∞C temperature accuracy. The AD7314 has a flexible serial interface that allows easy 2. Supply voltage of 2.65 V to 5.5 V. interfacing to most microcontrollers. The interface is compat- 3. Space-saving 8-lead MSOP package. ible with SPI, QSPI™, and MICROWIRE™ protocols and is also compatible with DSPs. The part features a standby mode 4. 10-bit temperature reading to 0.25∞C resolution. that is controlled via the serial interface. 5. The AD7314 features a standby mode that reduces the The AD7314’s low supply current and SPI compatible interface current consumption to 1 mA max. make it ideal for a variety of applications, including personal computers, office equipment, and domestic appliances. REV. A Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rights of third parties that may result from its use. No license is granted by implication or otherwise
under any patent or patent rights of Analog Devices. Trademarks and
Tel: 781/329-4700 www.analog.com
registered trademarks are the property of their respective owners.
Fax: 781/326-8703 © 2003 Analog Devices, Inc. All rights reserved.
Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION PRODUCT HIGHLIGHTS SPECIFICATIONS TIMING CHARACTERISTICS ABSOLUTE MAXIMUM RATINGS ORDERING GUIDE PIN CONFIGURATION PIN FUNCTION DESCRIPTIONS CIRCUIT INFORMATION CONVERTER DETAILS Temperature Value Register Serial Interface Read Operation Write Operation MICROCONTROLLER INTERFACING MOUNTING THE AD7314 SUPPLY DECOUPLING TYPICAL TEMPERATURE ERROR GRAPHS OUTLINE DIMENSIONS Revision History
